I used to have a Wireless Linksys for 4 pcs, i created a home network (Files & Printers) between my 2 pcs n 1 laptop, and Media Sharing in WMP11 with Xbox360 works. now that i got "2700hg-b Wireless 4pcs" I still got Net, fast installation, but i cant get into any of my pcs, and media sharing from wmp11 is not being detected on my 360, any help?.. i know its not my antivirus (Symantec), its the firewall or something from the new ROUTER!
SOURCE: Email problems with a WiFi network using a BT 2wire 2700HG
because you have a third party email account you will have to go into the email accounts and in options look for my outgoing server requires authentication and tick the box. You may also need autorization from bt as they may not allow the incoming emails. also check that any antivirus programmes arent stopping the outgoing mail and putting them in the outbox.
SOURCE: home network with 2700hg-b and netgear wireless issues
You didn't say what operating system you have but check your Network and Sharing Center in Control panel and turn on the file and printer sharing feature in Windows.
Using Vista, click on Control Panel- Click on Network and Sharing Center-configure settings.
Hope this helps.
SOURCE: 1800HG ROuter + Home Network
Rather than try and explain how to set things up here (would be a rather long answer!)... follow the links below ;)
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Go here for instructions on setting up printer sharing
http://www.home-network-help.com/share-printer.html
go here to setup file sharing
http://www.practicallynetworked.com/sharing/xp/filesharing.htm
You can listen to your favorite music without having to carry your laptop everywhere by sharing your music library on a wireless network. Here is a tutorial to show how to stream music from one laptop to another. Using
this method digital media such as videos and pictures can also be
accessed from anywhere easily. By the following method you can listen
music or view your photos or movies stored in your computer from
different places in the network.
First we'll connect the server laptop to a wireless
home network. This laptop has Windows 7 with Media player 12 and it has
all the music, videos and media that you want to share. Right-click on
the Internet notification area and select 'Open network and sharing
center'. Now, click on 'Connect to a network' and from the list of
networks, choose the preferred one and connect. Enter the secure
network key when prompted.
Let's create a 'HomeGroup'. From 'Network and
Sharing Center', click 'HomeGroup' and then 'What is a network
location?'. You'll see a window with three options. Select the first
one that says 'Home Network'. In the following window, select what you
want to share and click 'Next'. Follow the onscreen instructions and
Click 'Finish'.
In 'Network and Sharing Center', click 'Change
Advanced Sharing Settings' and make the changes. Then go to 'Media
Streaming Options' and allow people you want access to your files. Open
Windows Media Player, go to 'Stream' and click 'Automatically allow
devices to play my media'. The content you chose to share is now on
this network.
To access this content on a client PC or laptop,
first connect the machine to the same wireless network as the server
laptop, using the previous procedure. Vista users can right click and
directly select 'Connect to network'. Assuming that both laptops are in
the same network, open Windows Media Player and see of you can find the
shared server laptop in the left pane.
To find shared media on the network and to share
media from the client PC, in WMP, right-click on Library and click
'Media Sharing'. Here, you can allow or deny access to other PCs and
find the media you're looking for. Click 'OK' when you're done. Now,
the server PC will appear in WMP and other functionalities will remain
same. You're now ready to play the music which is stored on the server
PC.
