I can't seem to get my camera to work. I dropped it a long time ago and I just ended up buying a new one, but I want to try and fix my old one. the old camera is a canon sd630--I can turn it on if I set it to the "display" and just view my pictures but when I try to switch it to "camera" or "video" it won't take any photos? It turns on, there's this little noise like it wants to come out and the light turns green, but I can't view anything or take photos? Please please help.
SOURCE: Not reading my memory card
You may have bent or broken contacts inside the card slot. It's tough to see, but if you look deep inside the slot, you may notice a contact bent or broken. If you're not able to see any damage inside, try taking a cotton swab with some alcohol (isopropyl, not rubbing or drinking type), and cleaning the contacts.
SOURCE: Unable to download photos from Canon 350D
when downloading from my EOS 350D I get the message
'Camera launcher exe has stopped working'
I have Vista Home Edition
I am getting desperate to find a solution!!
SOURCE: CANON POWER SHOT SD750 DOESNT TAKE PICTURES BLACK SCREEN
DON'T DUMP YOUR CAMERA JUST YET! I HAVE BEEN ABLE TO LOCATE SOME INFORMATION ON YOUR CAMERA AND SOME THINGS FOR YOU TO TRY. FIRST YOUR CAMERA SITE SAYS THERE IS A SWITCH ON THE BACK SIDE OF YOUR CAMERA THAT SAYS " DISP " WHICH I ASSUME MEANS DISPLAY. PLEASE TRY PUSHING THIS BUTTON AND SEEING IF THIS WORKS? NEXT YOU NEED TO TRY TO REST YOUR CAMERA. THAT IS DONE BY GOING TO SETUP>CHOOSE RESET> HOLD DOWN MENU KEY FOR 5 SECONDS AND SEE IF THAT SOLVES THE PROBLEM. THE NEXT SOLUTION MIGHT BE THAT THE CAMERA FIRMWARE MAY NEED TO BE RELOADED TO RESET THE CAMERA TO FACTORY DEFAULTS. I KNOW IT SOUNDS LIKE A LOT OF THINGS, BUT THEY REALLY DON'T HAVE A SIMPLE ANSWER TO THIS PROBLEM. IF YOU NEED MORE HELP, REPLY TO: ARCLIGHT1217. GOOD LUCK!
SOURCE: Canon Rebel XS says it's busy
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS.
Installation of this Canon EOS Rebel XS firmware version 1.06 update will solve these problems:
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
I hope that helps.
