SOURCE: pentair whisperflo pool pump motor replacement
No there is a cover on the other side of the motor thet comes off and with a 9/16 wrench holding the shaft - spin the impeller off
SOURCE: Hello, I have a pentair
turn the pump off, remove the lid and pump basket. reach your finger inside to see if there is any debris caught in the impeller. MAKE SURE the pump cannot come on at any point while you're working on it.
That should do the trick, if not, investigate an air leak on the suction side of the pump. Causes: bad lid 0-ring, threads on suction fitting leaking air in, or if there is a union on the suction side, make sure it's tight and the o-ring is in good condition (add lube as necessary).
