Samsung SGH-A877 Impression Cell Phone Logo
Anonymous Posted on Jul 30, 2012
Unblock number on samsung lafleur
Help, I cannot unblock phone numbers once I have blocked them. Does anyone know how to unblock? Thank you!
  • Anonymous Jul 31, 2012
    and sorry, no, the two solutions below don't seem to do it, I think they have changed the system since 2009
5 Related Answers
Anonymous
  • Posted on Jan 19, 2010
SOURCE: how do you unblock a phone number on a samsung
you're looking for the reject list
here's how you get to it:
click settings
click call
click general
click auto reject
it shows the reject list
lastly, click the trash can next to the name who's you want to remove from the reject list.
That's it!
Anonymous
  • 7752 Answers
  • Posted on Jul 04, 2008
SOURCE: how do I block an incoming number on my nextel phone
menu/settings/call barring
Anonymous
  • Posted on Mar 21, 2011
SOURCE: samsung wave gt-s8500. how do
Go to messages>settings>general settings>block messages>then delete any blocked numbers you accidentally blocked! hope this helps. :)
Anonymous
  • Posted on Oct 21, 2008
SOURCE: how to remove numbers from the reject list on the samsung sgh-j600 mobile phone?
thanks a lot Bajanguru you should have said that it was an option to reset the phone now all my stuff is gone.
Anonymous
  • 10 Answers
  • Posted on Aug 29, 2009
SOURCE: i have a samsung tocco lite how do you unblock
i had the same problem myself
all you need to do is go on
Settings >> Application Settings >> Call >> All Calls >> Auto Reject
Then All You Need To Do Is... Click On The Recycle Bin,, If You Want To Get Rid Of That Number :)
I Hope This Helped :)
Jessica xx
16helpful
2answers
I have accidentally blocked a number on my samsung gt e2121b and now cannot receive texts from it. how do i unblock it?
Hi To unblock the accidentally blocked number you need to do the following Press the MENU key Select MESSAGING Scroll down the list and select SETTINGS Select TEXT MESSAGE Select BLOCK NUMBER Highlight the number you wish to unblock and select OPTIONS Select DELETE Select either DELETED SELECTED or DELETE ALL and press OK Briefly press on the ON/OFF button to return to the Main Screen
27helpful
6answers
My uninor sim is blocked so please tell me puk code, thank u
my sim card is block please unblock my sim card my ph:8291756838
14helpful
3answers
What is the puk code for a Samsung Genio?
PUK code can be give only by your network provider which is specific for each and every mobile phone.
Contact your SIM customer care service department over the phone. It's free of cost to get the pin or PUK no. If you can't contact through your phone, get some other phone and contact them or go to the nearest service outlet of your service provider.
There is no other way than to follow the above procedure..
Take care
1helpful
My globe sim card requires puk # what will I do? I was affected by Typhoon Undoy last year. please do help me to fix my concern thank you.
PUKs, or personal unblocking keys, are used to unblock a mobile phone which becomes blocked. Mobile phones may become blocked when a PIN (personal identification number) is entered incorrectly on three consecutive occasions. In some instances, the phone may become blocked, which requires a PUK to unblock it, and in other instances, the SIM (Subscriber Identity Module) card itself becomes blocked and again will require a PUK to unblock it.
Mobile phones are also blocked when they are reported stolen and if there is an outstanding payment on the account.
It is important to differentiate between unblocking phones (using a PUK) and unlocking mobile phones (using another type of code). More information on unlocking phones will be available here in the very near future.
NOTE: It is a criminal offence for anyone to attempt to unblock a mobile phone, other than the network provider who put the block on the phone.
If your phone has become blocked by mistake, for example you have entered the PIN incorrectly on three consecutive occasions, then you need to contact the mobile phone network operator with your details. To explain a little more, specific to your mobile phone network, use the links above to navigate your way to the specific PUK details for your mobile phone network operator.
142helpful
3answers
How to unblock a number on a samsung impression
Unblocking a contact that you accidentaly blcoked is easy with Samsung impression phones.
Select 'Settings' on the home screen
select ''Calls'
select 'General'
Select 'Auto Reject'
There, you have an option of turning it 'ON' or 'OFF'
Or you can select the numbers that you want to continue 'REJECTING' or otherwise
Then 'SAVE'.
I hope this helps.
33helpful
2answers
Kx-TGA641T how does one unblock blocked number
http://ww2.justanswer.com/uploads/MCVGreg/2009-09-21_023145_KXTG9331-Remove-Blocked.pdf
Viewing/editing/erasing block call
numbers
1 {MENU} -> {#}{2}{1}{7}
2 {V}/{^}: Select the desired item.
~To exit, press {OFF}.
3 Proceed with the desired operation.
■ Erasing a number from blocked list:
{Erase} -> {Yes} -> {OFF}
you can also edit:
■ Editing a number:
{Edit} -> Edit the phone
number. -> {Save} ->{OFF}
3answers
Can i block phone numbers on the samsung e770 mobile phone?
Sir, you can block phone no.s but not from your phone. This feature is not supplied in any phone. You have to contact the Service Provider for the feature. They will enable a Black list Feature. In this feature, you can put any no. of phone no.s which will never reach your phone unless you remove the no. from the Black list.
Thank you Sir, Have a nice day.
2answers
Unblocking number
just a guess....
search for " screening or block number " at phone/numbers or message/text it may help..
then the rest is up to you..
Unblock SIM number for Motorola SLVR
You cant unblock your sim you will have to go to the customer care and get the sim replaced.
99helpful
16answers
SAMSUNG SGH-E250 puk blocked
Hi everyone
Every PUK code is unique so nobody can tell you your PUK number, but i will tell you what you can do!
1) If you still have your packet that your Sim Card came in, you should find your PUK number in there, if you don't have the packet, please read bellow.
2) You must get a phone that is on the same network as your phone and call the networks Customer Care and ask them for your PUK number, they will ask you for your phone number, then they will tell you your PUK number. Once you have done this, you will be able to reset your Pin number so you will be able to go into your phone again.
Please also remember to give me a good rating on my profile.
Kind regards
Dustin Ellse
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
