No bootable device
SOURCE: I have emachine t5010 not booting. I receive error message
This means the system can't read from your hard drive. This might be due to a loose data or power cable connection. You can open the computer and make sure all the connections are firmly seated. It might also be a power supply problem. The hard drive may have failed. Or the drive may been wiped clean (or at least had its boot sector destroyed) as the result of a virus. A problem on the system board might have developed. Troubleshooting would involve booting from a CD to run diagnostic software, substituting known good parts, or both.
When you boot up to the log in screen type in administrator as user if you cant log in
During the boot up process you will see on the screen for a short amount of time a certain key to enter set up press and hold that key to enter set up BIOS scroll to set user password or supervisor password you can change or remove the password from there if you are still unable to change your password you might download
http://download.cnet.com/%7Bvalue=http://www.download.com/ubcd4win/3000-2086_4-10550208.html
UBCD4Win is a bootable "live" CD which contains software that allows you to change paswords repair/restore/diagnostic almost any computer problem also has a bios reset tool which remove your password and BIOS password although you will have to use a computer with an internet connection you will have to burn it to a disk as an iso then change your firtst boot device to cd During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart (note after you have removed the password you must go back and change the first boot device to your hard drive)
Hope this helps
Hope this helps
if you are not the computer administrator and have not assigned a bios
password during the boot up process you will see on the screen for a short
amount of time press a certain key to enter set up Press and hold that key
during the boot up process to enter BIOS scroll down to set user password or
supervisor password you can change or remove your password from there also
click start control panel user
accounts on the users tab,click the name of the computer administrator you must
have full control can change the password there
Also
i have used this software and no that it works although
you might have to get a computer with an internet connection to download and
burn it to a disc
http://majorgeeks.com/download.php?det=5710
UBCD4Win is a bootable CD which contains
software that allows you to repair, restore, or diagnose almost any computer
problem also has a bios reset tool which can remove your password and bios
password
a disk as an ISO then you will have to boot from the disc
to cmos to restart (note after you have removed your password you will have
change first boot back to your hard drive)
Hope this helps
