SOURCE: kenmore washer not spinning or agitating
hi thanks for the question don't take back off please. the problem is with the motor coupling located at the motor & transmission to repair . 2 screws at console .remove .lift console .remove 2 brass clips disconnect wiring plastic disconnect pull cabinet towards you .put a block under left front lift up remove the pump 2 spring clips .remove motor wireing . remove the motor replace the motor coupling thanks the appliance doc
SOURCE: kenmore series 70 model 24732
check the lid switch. that is the most common problem if not spinning.
tnx 4 using fixya,
drcool
SOURCE: washer makes noise during spin cycle, wont agitate
Sounds like your transmission is going out. Yes washing machines do have transmissions, I know, strange huh? Anyway, the transmission is connected to your motor and the motor makes it spin and agitate. The transmission goes up into the tub and is basically the agitator. When the gears go bad in it, it will start making a loud noise almost like a grinding noise and won't spin properly or agitate. It is expensive to fix, almost as much as a new washer. Your best bet is to buy a new machine unless you can find a good deal on a refurbished transmission. Those will sometimes run only around 150 dollars. A new one though will cost you around 250. You might be able to find a good deal though. They are easy to fix, I myself replaced one in 15 minutes once when I was still a repair man for Sears. So, check out some prices and see what the best way to go is for you. If you have any questions about installing it let me know and I can give you an easy step by step walk through on it. I hope this helps you out and good luck.
SOURCE: my kenmore elite oasis runs fine but wont go through spin cycle
Try replacing the motor coupler between the motor and pump three small pieces about 18.00 dollars at sears parts store.
SOURCE: kenmore 80 series washing machine fills but wont
My bet is on the drive coupler. if you can here the motor run and the machine will drain water then 99.9% it will be the drive coupler.
This coupler is behind the motor and is what conects the motor with the transmission.
