Forgot my administrator password
Recover forgotten administrator password with article support: http://www.windowspasswordsrecovery.com/articles/win7/recover-windows-7-administrator-password.html
You can reset Administrator password with Windows built-in administrator account:
1. Log on with the guest account on Vista, then right click computer, and choose Management.
2. Expand Local Users and Groups and Users in the console.
3. Right-click Administrator account and select Properties.
4. On the General tab, clear the Account is Disabled check box.
5. Close the console.
Now the super administrator account is successfully enabled. Next, you can easily reset the forgotten admin password from "Start->Control Panel".
If the above method can not help you, you can use Smartkey Windows Password Recovery to help you to reset the password, and see the detail direction from http://www.recoverlostpassword.com/products/windowspasswordrecovery.html.
SOURCE: I forgot my administrator password
Start it in the regular safe mode, log in as administrator, from here you can clear any user passwords.
SOURCE: laptop admin password
IHi,
If your looking to unlock a BIOS Password, then yes, a Make & Model Number would be handy. If your looking for the Admin Password that logs you into Windows then you can use this utility to change or remove the admin password easily :
http://home.eunet.no/pnordahl/ntpasswd/
What you need to do is to reset administrator password. I recommend you a third part utility so that your can reset your password without erasing anything.
1. Login to a computer that can link to Internet. Download <a href=http://www.passwordunlocker.com>Windows Password Unlocker 4.0 </a> and decompress it on that PC. Note that: there is a .ISO file. Burn the .ISO file to a CD.
2 Get out the newly created CD and insert it to the locked computer.
3 re-booted the locked computer and then followed the process of instructions. Just a few steps, the old password was removed.'''
4 Setting new password:
Step one: Open the "Control Panel"
Step two: Click the "User Account "
Step three: Select the account you wanna to set a new password.
Step four: Click "changing Account " and "set up password", then fill out the form as listed. Click "Create Password".
SOURCE: forgot the administrator password to my dell
Forgetting your Windows administrator login password. With no way to get into the system, you can’t even perform basic maintenance, let alone a thorough tune-up. Formatting is always an option, but we consider that a last resort. (Plus, guess who’s going to have to help reinstall all the programs lost after a wipe?) But all hope is not lost. There are a few ways to actually retrieve a lost Windows account password. Read on, and we’ll show you the light.
====1st Method====
The first thing which you check if you forget login password. When we install Windows, it automatically creates an account “Administrator” and sets its password to blank. So if you have forget your user account password then try this:
Start system and when you see Windows Welcome screen / Login screen, press ctrl+alt+del keys twice and it’ll show Classic Login box. Now type “Administrator” (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from “Control Panel -> User Accounts”.
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
====2nd Method====
1. Reboot your machine.
2. Press F8 before the Windows boot screen appears.
o Do not press F5 as used on the NT/9x series of Windows.
3. You will be be prompted with a boot options menu.
4. Select the Start Windows in Safe Mode option.
5. Click through several self-explanatory screens until your reach the familiar 'Welcome' screen.
6. Note that this welcome screen is limited to 256 colors and 640x480 resolution because the primary graphics will have been set to the Windows Safe Mode software VGA adapter. You will not be able to change this mode even in Display options, while Windows is running in Safe Mode.
7. Find the icon for the Administrator user. If the default settings of your system haven't been changed, there should be no password for this account.
o The Safe Mode Welcome screen might display some of the other users on your system.
8. Login as the admin.
9. Press Yes at the prompt asking if you would like to continue using Safe Mode.
10. Continue on to the User Settings control panel. Here you can change any of the other passwords for user on the machine. Make any changes you want.
11. Reboot your computer. As long as you don't press any keys (i.e. F8) during the boot-up the computer will startup normally.
12. Login as the user for which you set the password.
====3rd Method====
Windows XP and further versions also provide another method to recover forgotten password by using “Reset Disk”. If you created a Password Reset Disk in past, you can use that disk to reset the password. To know more about it, please visit following links:
http://support.microsoft.com/kb/305478
====4th method====
Comparatively, using windows password Recovery Tool utility is a reliable and convenient method for solving the password problem. Normally, the program can easily reset the password to “Blank” with no -reformatting or installation. Do all the job for you automatically. Unfortunately, it is not safe to use some free recovery tool to recover windows password. So here is the recommend recovery tool:windows password Recovery Tool 3.0 .
Offical site: http://www.windowspasswordsrecovery.com
you could see the recommendation of articlesbase.
http://www.articlesbase.com/security-articles/how-to-reset-recoverfind-forgotten-windows-nt-2000-xp-2003vista-administrator-password-1282019.html
====5th method====
If it doesn't work above ,I hope that you have some hacker friends.
====Reference resource====:
http://windowspassword.blog.com/
http://www.wikihow.com/Recover-Windows-Administrator-Password-if-You-Forgot-It
http://www.articlesbase.com/security-articles/how-to-reset-recoverfind-forgotten-windows-nt-2000-xp-2003vista-administrator-password-1282019.html#
http://www.instructables.com/id/How-to-Reset-Recover-Forgotten-Windows-NT-2000-2001/
SOURCE: I forgot my bios administrator
I'm afraid this will need to be sent of for repair, as it involves open the laptop up and shorting out to connectors to wipe the password. HP do do this but I know it is expensive. If you go to a local repairer, make sure that they is confident else they could blow the whole laptop.
