Cell Phones Logo
Anonymous Posted on Jul 29, 2012
What does Heap Check mean ?
Camera will not come on it says Heap Check!
Jason Simmonds
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 47 Answers
  • Posted on Jul 29, 2012
Jason Simmonds
Expert
Level 2:
New Friend:
Greenhorn:
Answers
47
Questions
0
Helped
13254
Points
127
Hey kdcalloway33,
Heap check mode, which is similar to the existing block check mode, is a debugging tool that flags certain coding errors related to the use of ECB heap to help you determine when an application is changing or accessing storage beyond its allocated heap buffer or accessing an ECB heap buffer after it was released. See z/TPF Main Supervisor Reference for more information about heap check mode.
Check out this link for more info
Good Luck
I have a radio shack pro 106 scanner.it is coming up heap error 21c321.What is this and how do I clear the error/
that means that you have a trunking system that has no sites assigned to it. If you do not have a 3rd party PC software, download PSREdit 500 from here ( 30 day free trial) Upload to the program then back to the radio and it will clear the heap error. http://www.psredit.com/psredit500/download.html
How do i fix heap error 221521 ; 221c on pro 106
That means that you have a trunking system that has no sites assigned to it. If you do not have a 3rd party PC software, download PSREdit 500 from here ( 30 day free trial) Upload to the program then back to the radio and it will clear the heap error. http://www.psredit.com/psredit500/download.html
Nokia 2700c 2 i me download after finis phone answer memory full plz help me
it must be saying heap memory, that is ram of your mobile, it only happens when you run a game or app using high heap memory, or try to clean phone memory!
Jan 29, 2013 • Cell Phones
Got a new memory card for my camera and im getting an "Out of Memory" warning
Most digital cameras will work with only with specific memory cards. You can't just buy any old card and expect it will work in your camera. Approved cards for Nikon E5700 are listed on page 159 of the English version manual. (In the Technical notes.) Also, if you insert or remove the memory card with the power on it could render the card unusable and, of course, you must insert the card in the correct orientation.
I assume you have not taken a heap of images in high resolution and simply filled your new card.
3helpful
2answers
I am using samsung champ i am getting java error so please sms me on 9158461811
Kab ye error msg display karta hai pura question saaf saaf likho
there are many types of java error which occurs in different conditions
My leica d-lux 3 has started to delete photos on its own.when i check playback a heap of photos are pitch black.can it be the camera or sdhc card?
Your post is confusing, are you saying that photos which were once properly exposed are now black, i.e. underexposed, or have they disappeared completely?? Neither is believable.It is to be the camera, unless the problem is that the camera can no longer read the card.I am afraid your information is not clear enough Take the card out and check what is on it in your computer or someone else's if you don't have one. Try a different card (preferrably a different make) in the camera, just take some random shots and see what happens. Please report back.
1helpful
I'm trying to launch my email and it says not enough heap can't launch games and applications. What does that mean?
this mean that your cell phone has not that much ammount of memory to deal with that software
8helpful
I have a Samsung SCH-r560. Heap check????
After doing further research online I found that all I had to do is remove the battery and put it back in. It works perfectly now.
H I hace a DMC TZ11 camera. I took a heap of phots today but didn't have the memory card in. Is there any way I can access the photos. Thanks
Install a memory card and turn the camera on. Look in the Setup menu, and there should be a "Backup" or "Copy" entry which will let you copy pics to/from internal memory.
2answers
Film rewind crank stuck in up position nikon n2000
Move it a bit (some half circle)back and forth. The slot may be in wrong position related to the roll inside. It should click in when you get the slot in right angle.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
