Crown Ouku 7" Touch Screen Dvd In Car Player Audio Receiver Rds Radio Universal Logo
Viki Falgout Posted on Jul 29, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bluetooth code for ouku 7
Need the PIN for the bluetooth to connect to my phone
MARC CHESTON
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 14, 2013
MARC CHESTON
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2580
Points
wwlvictoria
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Crown Master 1,001 Answers
  • Posted on Dec 17, 2016
wwlvictoria
Crown Master
Level 3:
Renaissance:
Answers
1001
Questions
0
Helped
603668
Points
6027
Portable Bluetooth 4.1 Receiver Wireless Multipoint Connection Audio Music Adapter with 3.5mm AUX Port and Hands Free Calling for Home Audio Music Streaming Sound System Amazon com Charm sonic Portable Bluetooth 4 1 Receiver Wireless Multipoint...
Mike Garcia
Level 1:
New Friend:
  • Posted on Mar 19, 2014
Mike Garcia
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
2580
Points
I tryd 0000 1234 8888 still nothing even also hit master reset
How do i hook up gps to back of ouku LITB200-7 cd player and what do i need
The only reason I can see you wanting to do that is to hear the directions over your player's or car's speakers. Very likely you cannot physically hook up your GPS to the back of the player, but if the GPS is Bluetooth-capable, you can connect it to the player wirelessly (no physical hook up required) via Bluetooth. Or you can just use the GPS as a standalone unit, the way it was meant to work.
tip
How can I reset a Bluetooth?
<p>Using a Bluetooth device for mobile phone or computer, it asks for a PIN or security code. The connection between two Bluetooth devices is based on this code. If you're not interested in connecting both devices in the future, you need the code again. On reset the Bluetooth devices to remove the existing code and will prompt you to enter in case you decide to return to be switched. <br /> <p><br /> <p>1. Go to the menu on your mobile phone. Find the connection options and select the "Bluetooth" option. In the Bluetooth menu, you can see the devices currently associated with the phone. <br /> <p><br /> <p>2. Use the arrow keys of the phone to disconnect the device you want to select. You will see a number of options from the context menu. Choose "Remove / Reset PIN." This will switch back to the default security code, usually '0000 '. <br /> <p><br /> <p>3. Disconnect the connection of Bluetooth devices; simply select the 'Delete' / 'Remove' option on your mobile phone. When you pair the devices in the future you will be writing a new code. <br />
on Jun 26, 2011 • Cell Phones
3helpful
2answers
Need bluetooth code for eonon d2216
D2216 Bluetooth code/pin is 5802
4helpful
3answers
Common Issues with Crown Ouku 7 Touch Screen 2 Din Car Stereo Dvd Player Radio Bluetooth Ipod Tvcamera
how can you hook up an aftermarket amp to your Ouku 2 DIN DVD player? i can't figure this out and iv looked everywhere.
I need the factory pin code I have lost it
Hi,i think you have problem with the code used in pairing your bluetooth device,the default code to connect to your bluetooth device is "0000".
Good luck
12helpful
2answers
My RAZR V3 won't pair with 2009 Chevrolet Silverado bluetooth
http://www.gm.com/vc/bluetooth/index.jsp?brand=chevrolet&landing=true
PAIRING A PHONE WITH YOUR 2009 Silverado
Before you begin:
To take advantage of the Bluetooth for Chevrolet functionality, you must first pair a Bluetooth-enabled phone to a Bluetooth-enabled vehicle.
Note: If you do not pair a Bluetooth-enabled phone, all calls will be made using OnStar® Hands-Free Calling.3
Some additional tips:
1. You can pair up to five phones with your 2009 Silverado.
2. Your system automatically recognizes the first phone you pair. To use a different paired phone, you must
select it using the "Change Phone" command.
3. Only one paired cell phone can be connected to your system at a time.
4. When the vehicle is in motion, you cannot pair a phone.
5. Pairing should only need to be completed once (unless changes to the pairing information have been made, or the
phone is deleted).
PAIR YOUR PHONE
Set up phone - Turn Bluetooth 'ON':
1. From the main screen, select "Menu"
2. Select "Settings & Tools"
3. Select "Connections"
4. Select "Bluetooth"
5. Select "Setup"
6. Select "Power"
7. Select "On"
Set up vehicle - Enter 'Pairing' mode:
1. Press and hold the Push to Talk button for two seconds
2. Your system will respond with a "Ready" message followed by
a tone
3. Clearly say "Bluetooth"
4. Your system will respond with a "Bluetooth ready" message
followed by a tone
5. Clearly say "Pair"
6. Your system will respond with instructions and a four-digit
Personal Identification Number (PIN); you will need to enter
this PIN on your phone
Begin the pairing process on your phone:
5. Select "Hands free"
6. Select "Look For Devices"
7. Select "General Motors"
8. Select "Yes" to bond with General Motors
9. Enter the PIN code provided by the vehicle
10. Select "OK"
Finish the pairing process in your vehicle:
1. The system will prompt you to give a name to your phone
2. Say a name that best describes your phone (example: Corey's
phone); this name will be used to indicate which phone is
connected
3. Your system will ask you to confirm your name
4. If you confirm that name, the system will respond with the
message: "'<Phone name>' has been successfully paired"
Bluetooth code/pin
I suggest you to go back to the store that you bought your cell phone from and they will tell you the code pin.
2answers
Pioneer Bluetooth
The Z2 default code is 1111
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Mike Cairns
Mike Cairns
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
