Bosch 24 in. SHU43 Built-in Dishwasher Logo
Posted on Sep 04, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Bosch Exxcel Dishwasher, stuck at 1 minute to go
My Bosche Exxcel dishwasher initially stopped mid cycle, full of water, I was told this was due to something hard stuck in brushes, - now removed offending article.
However now runs, if you open the door lets say at 31 minutes to go, it restarts at 34 minutes........then at end of cycle stays at one minute to go and does not altar from this. Has anyone got any ideas?
  • 2 more comments
  • lbaroch Dec 19, 2008
    My dish washer keeps going and wont stop..... I have tried several different cycles and cannot get the dishwasher to drain. How do I manually drain it.
  • Anonymous Dec 22, 2008
    i have the same problem
  • puzled Dec 23, 2008
    Have the same problem. The washer maintains water and also sticks on one minute?
  • Pat Wells
    Pat Wells Apr 05, 2018
    Mine did the same thing. I shop vac’d the water out and cleaned the drain line. Turned the breaker off and on ( the old turn it off annd on trick) still stuck on 1 minute. I got mad and slammed it shut, the timer lit up 2:20. I ran it and it worked fine. I’m guessing it’s a latch issue. Hope it works for you.
Steve F
Level 3:
  • Master 1,361 Answers
  • Posted on Sep 04, 2017
Steve F
Master
Level 3:
Answers
1361
Questions
Helped
567019
Points
3788
Make sure the drain pump is clear of any blockages and obstructions and that the drain hose wasn't kinked when you re-installed it.
3 Related Answers
Anonymous
  • 3130 Answers
  • Posted on Apr 14, 2006
SOURCE: Electronic controls don't count down properly
Your problem is the electronic control board and unfortant that you cant repair or even get parts for it . Only if you get the whole control board will you fix your problem assy unless you find a good appliance man that repairs electronic control boards
Carmen Mikulic
  • 415 Answers
  • Posted on Sep 25, 2008
SOURCE: Bosch Exxcel Dishwasher operating instructions
hi there,
can you supply the complete model # for me and also an e-mail address and i will e-mail you the pdf file.
thanks
Anonymous
  • 457 Answers
  • Posted on Mar 03, 2010
SOURCE: My Bosch logixx dishwasher is sticking on 1 minute
100% add the jet dry until it is completetly filled then close the dispenser door and lower then raise the door.repeat this at least three times then check and fill if you can still add more. then after doing that b4 you start the machine run the hot water to get the right temp. when the water is hot enough then start the machine.
Sgv5613gb
Bosch sgv5613gb will not finish cycle stopping on 1 minute and the dishers are not dry. Is it just a case of resetting the machine and if so how?
1helpful
When I press the start button, Bosch dishwasher (model SHY56A 05UC) just keep running the motor pumping the water out of dishwasher, irrespective of: 1) the wash cycle it is on, 2) whether the door is...
what is happenig i believe and has happened to me 2 times is that the water level float that is on the left side of dishwasher is stuck.
Either remove side panel and flick lever or pull dishwasher out and tap lower portion of panel and this will cause the level to move and then see hat happens
16helpful
2answers
2helpful
S5N27B keeps stopping mid cycle
If the cycle doesn't complete, check these:---
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Bosch exxcel multi programme ....programme gets to 1 min and then stays there. on the quick cycle on the auto cycle it gets to 60 min then returnsto 140min on the timer... thankyou
this is caused by incorrect water levels the appliance takes in too little water at final rinse and generates erro code 1 this is what you are getting it isnt 1 minute to go it will need the dishwasher equivalent of colonic irrigation several tubes will be full of fatty deposits,using the quick wash a lot will make this happen more often you will need an engineer to sort but shouldnt need any parts.
1helpful
Bosch Exxcel dishwasher "check light" indicator
**** out the water with a shop vac. Consult manual for self diagnosing keypad codes.
My bosch exxcel dishwasher will not drain after wash cycle
That is because the water level switch activated by the floating sensor is stuck.
You probably need to have the water level switch replaced.
You can find parts on websites below:
You can find replacement water level switch , and schematics on websites below:
BSH - Bosch Customer Service
Appliance411: Repair Parts
how to mend it .com - ~~ Wiring diagram for BOSCH Dishwasher.
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
