Canon HS-1200TS Calculator Logo
Anonymous Posted on Jul 29, 2012
How do you find square of a number - Canon HS-1200TS Calculator
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Canon Master 102,366 Answers
  • Posted on Jul 29, 2012
Canon Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10433499
Points
622693
The square of a number is by definition the number multiplied by itself. You can calculate the square simply by multiplying the number by itself.
2answers
How to calculate the square root
The square root is the second function of the "3" key. To calculate the square root of 3, press 3 2ndF 3 =
How to use square root for non square numbers for casio graphing calculator
You can use the square-root function for any number, whether it's a perfect square or not. For example, to calculate the square root of 2, press SHIFT [square-root] 2 EXE .
[square-root] is on the x^2 key, just to the right of the ALPHA key.
1helpful
How can you use the square root key to find the square root number?
Press 2nd [square-root], enter the number, press ) =
For example, to calculate the square root of 5, press 2nd [square-root] 5 ) =
2helpful
Double Squares A double-square number is an integer X which can be expressed as the sum of two perfect squares. For example, 10 is a double-square because 10 = 32 + 12. Your task in this problem is, given...
20 1105 1991891221 510644794 3 0 421330820 4 65 1941554117 2147483645 801125 1000582589 27625 1048039120 1022907856 2147483646 1041493518 1096354453 1740798996 71825
2answers
A window glass 4 ft. 2 in. by 2 ft 10in. find its area. show the figure
Below is calculation of window glass area :
4.167 ft '------------------------------------'- ' ' ' ' 2.833 ft ' ' '------------------------------------'--
Total area = 4.167 ft x 2.833 ft = 11.81 ft2
3helpful
I cant figure out how to get the square root of a negative number
The square root of a negative number is an imaginary number, and the TI-30XA does not deal with imaginary numbers.
However, the square root of -x is equal to i times the square root of x. So, to calculate the square root of -4, for example, press 4 square_root = and read 2. Thus the square root of -4 is 2i.
Find missing number in this progression: 15 26 34 51 ? 84 96 125 [email protected]
The missing number is 61.
Look at perfect squares: (1,4,9),16, 25, 36, 49,64, 81,100,121
Then look at the given progression 15, 26, 34, 51, x, 84, 96,125
Take differences from the closest -1,+1, -2, +2, -3, +3, -4, +4
(15 is 1 less than 16 = 4 squared,
26 is 1 more than 25 = 5 squared,
34 is 2 less than 36 = 6 squared,
51 is 2 more than 49 = 7 squared,
61 is 3 less than 64 = 8 squared,
84 is 3 more than 81 = 9 squared,
96 is 4 less than 100 = 10 squared,
125 is 4 more than 121 = 11 squared)
Square number between 490 and 500?
Perfect squares are the product of a whole number and itself. Given that 22 squared = 484, and 23 squared = 529, I'd say the answer to your question is that there is no square number between 490 and 500.
1helpful
2answers
old marine
old marine
ZJ Limited
ZJ Limited
