Garden Logo
A
Anonymous Posted on Jul 28, 2012
How to fill hydrostatic transmission fluid on Poulan Pro
How do I check the transmission fluid? Thanks.
L Pfaff
Level 3:
Top Expert:
  • Poulan Master 11,573 Answers
  • Posted on Mar 25, 2016
L Pfaff
Poulan Master
Level 3:
Top Expert:
Answers
11573
Questions
0
Helped
3583797
Points
181713
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Fill Hydrostatic Transmission in Lawn Tractor
http://husqvarna.custhelp.com/app/answers/detail/a_id/387/~/maintenance---what-type-of-oil-is-used-in-the-hydrostatic-transmissions%3F
Craftsman Hydrostatic Transmission Fluid Change
4 Related Answers
Anonymous
  • 9 Answers
  • Posted on Jul 10, 2009
SOURCE: How do I check fluid level on YTH150 Hydrostatic Transaxle?
My Husqvarna hyrdrostatic transmission is sealed, and yours may very well be also. That means no changing the fluid.
Anonymous
  • 109 Answers
  • Posted on Apr 22, 2009
SOURCE: MTD PRO RIDING MOWER/LAWN TRACTOR 18 HP ENGINE HYDROSTATIC DRIVE
In the back of the mower...probably under the seat, there should be a lever to release the transmission, or it is on the back plate. As far as the noise when trying to move drive the mower, the brake in the back, next to the transmission is jammed, use a 1/2 inch wrench to loosen it maybe 1/4 turn and this should unlock the brakes
Anonymous
  • 389 Answers
  • Posted on Oct 29, 2009
SOURCE: transmission fluid low, hydrostatic transmission
Quoted from your Owners Manual. . . . .
TRANSAXLE PUMP FLUID
The transaxle was sealed at the factory and fluid maintenance is not required for the life of the transaxle. Should the transaxle ever leak or require servicing, contact your nearest authorized service center/department.
Anonymous
  • 3911 Answers
  • Posted on May 12, 2011
SOURCE: How do I check hydrostatic
first you need to know who made it and the model. there are only 2-3 companies making all of them.
look for a stamping on the bottom along the axle, if not there you are going to have to drop it out of the mower and find the info on top. possibly you could lift the seat up and see the top of the tranny to get this info.
once you have the maker and model of the tranny, find their website and download the service instructions. many of these are made with lubrication for life. meaning they can't be topped up or changed, if the fluid is low or bad you replace the whole thing.
How do I check hydraulic fluid on a troy built 0 turn LM
Slide the transmission oil drain pan from under the transmission oil filter. Fill the hydrostatic transmission oil filter reservoirs with new hydrostatic transmission oil. Pour the transmission oil into the reservoirs by hand. Fill the oil reservoir to the full line that is embossed on the side of the reservoir tank.
Sep 07, 2020 • Troy Garden
My poulan pro lawn mower jerks really bad when you go forward
Check belt from motor to transmission make sure all there is no debris affecting belt if not. You probably have bad drive plate or possibly a broken spring that could do real damage to your transmission. You can disassemble fairly easy just make sure you have large container to catch the fluid, you may want to find mfg. And model no and go to net to find parts list if possible.
Why is my Series 1000 LT1024 Hydrostatic Drive Cub Cadet not pulling?
In most cases the hydrostatic drives are not made by the company tractor or lawnmower.
This is in the owners manual.
The hydrostatic transmission is sealed at the factory
and is maintenance free. The fluid level cannot be
checked nor can the oil be changed. Always keep the
area around the transmission cooling fan free of grass
and debris at all times
Cub Cadet LT1024 Operator Manual
How to Change the Hydrostatic Fluid in Cub Cadet Lawn Mower
https://www.google.com/webhp?sourceid=chrome-instant&rlz=1C1GGGE_enUS385US385&ion=1&espv=2&ie=UTF-8#q=cub%20cadet%20hydrostatic%20fluid%20change
I hope that this can help. Tom
I have Poulan Por 54 inch deck,25 hp Kohler hydrostatic. After I mow on unlevel ground for about 30 min. Transmission makes noise jerks and won't go till it cools off. Will changing the fluid help
couldn't hurt to try but some cheaper mowers don't have a drain plug look on a parts break down on sears parts online but check the belt tension first
Apr 13, 2012 • Garden
Poulan Pro 300 42" cut
Likely a valve or check valve is frozen. Refer to your manual showing hydraulic circuits and it will probably be obvious where a blockage that prevents ANY oil flow to the drive motors could occur.
Jun 30, 2011 • Garden
3helpful
The mower gets slower and slower and then stops moving completely. I turn it off for five or ten minutes and it's okay ... occuring more frequently ....
The hydrostat transmission is low on fluid. Check your manual, some of these can be filled...most cannot. If yours can't be filled/doesn't have a fill opening, Husq is going to recommend to replace the transmission (sealed unit). There has been limited success by trying to top off the trans thru the vent tube. This is not a Husq approved repair, and is very slow and tedious. But it is a lot less expensive. Good luck!
Hydristatic slips
Try running it to warm up the fluid, drain the old stuff out and replace with a quality hydrostat fluid recomended by the mfg. Also change the filter if so equiped. you should be able to get ahold of the mfg. online or start here http://www.poulan.com/poulanpro/indexAction.do?id=default
Top Poulan Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Poulan Garden Expert? Answer questions, earn points and help others
