RECHARCHING MY DOMETIC RM2611
Hi, it is not as simple as recharging when it comes to an RV fridge. If you have lost your pressure then you need a replacement cooling unit. A Cooling unit can normally be changed in approximately 2 hours with no specialized tools needed. Our cooling units come standard with installation instructions. Arcticold cooling units are Bran NEW not rebuilt. Our Products are unmatched in quality and performance. Check us out
My Dometic 57915.531 will not come on at all when switch the fan to auto or on, heat or cool. I've checked all fuses, including the one on the control board, all are ok. Any ideas?.
Is your thermostat hot wired or does it take batteries?
Thanks so much for the response. It's hardwired. Since postin
Since posting this yesterday I fiddled around the control board, pulled the fuse (which was good), and reseated it, now the AC is working again but I have another odd problem with it. It seems that the compressor is kicking on and off about every 10 seconds or so. When it kicks in there's a major drop in what seems like power because the fan blows much slower. however it does blow cold air during this time. Then when it kicks off, the fan speed ramps back up but it blows warm air. Any thoughts on that? Thanks again.
Sold the trailer, thanks for the input.
