Http://www.msi.com/product/mb/760GM-P21--FX-.html
Hover your mouse cursor on the Download tab.
(Overview/ Specification/ Download/ Support/ Where to Buy)
In the drop down list click on - Manual
On this page under the subheading Download, click on the blue -
M7641v3.0.zip
On the next page click on the country name nearest yours.
Motherboard User Manual.
This is a Zip file. If you do not know how to open a Zip file, please state in a Comment, and I will guide you.
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
The Front Panel header is divided into two headers on the motherboard.
This you have stated, JFP1 and JFP2.
(Junction Front Panel 1, and Junction Front Panel 2)
JFP1 is for the Power On switch, HarDDrive activity LED, Reset Switch, and a two wire Power On LED.
JFP2 is for an internal speaker/buzzer, and a three wire Power On LED. (Dual color)
JFP1:
4 pins across the Top row.
5 pins across the Bottom row.
The pins on the Top row are numbered EVEN.
The pins on the Bottom row are numbered ODD.
Starting on the LEFT side coming across to the Right side, Top row;
Pins 2, 4, 6, and 8. There is NO pin 10.
Starting on the LEFT side coming across to the Right, Bottom row;
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED.
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the Harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. It is reserved for the factory to use.
D) Pins 2 and 4 are for a two wire Power On LED.
Pin 2 is for the Positive ( + ) wire.
If the PWR ON LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
F) There is NO pin 10.
JFP2:
3 pins across the Bottom row.
Starting on the LEFT side coming across to the Right, Top row;
Pins 1, 3, and 5. There is NO pin 7.
A) Pins 1, 3 and 5 are for a dual color Power On LED.
Pin 1 is for the Negative ( - ) wire.
Pin 2 is for a Yellow, or Orange part of the dual color Power On LED.
Pin 3 is for a Green part of a dual color Power On LED.
B) Pins 2, 4, 6, and 8, are for a speaker/buzzer.
Pin 2 is for the Negative ( - ) wire of a speaker.
Pin 8 is for the Positive ( + ) wire of a speaker.
Pin 4 is for the Positive ( + ) wire of a buzzer.
Pin 6 is for the Negative ( - ) wire of a buzzer.
For additional questions please post in a Comment.
Regards,
joecoolvette
Thank you so much. I guessed last night. I think I got it right.
No reason to guess Cooper. You have the Front Panel pinouts now, lol! So, did you download, and unzip the motherboard manual? Thank you for the rating, and kind words!
I have the same MB but by placing the wires the way you said and even by yhe manual mine will turn on but no video or anything except the power light on the front of the case.
SOURCE: How do I attach the front USB, speaker and mic of the case to MB?
Follow that arrows on the pictures. Plug the USB Front Panel Cable.
SOURCE: msi 6524 jfp2 connections
You can download the manual from the link below: http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=303 This has the installation instructions. Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: i cannot reads the pinouts on the mb albatron
ftp://ftp.albatron.com.tw/product/it/mb/PDFzip/Manual/VIA/K8M800-754/K8M800-754_EG102.pdf
Download the manual, on page 15 you will see how ro connect the front panel cables
And here is the supportsite for that mobe incase you need any drivers
http://www.albatron.com.tw/English/product/mb/pro_detail.asp?rlink=Specification&no=196
If you need more help just let me know
Good luck
Dont forget to RATE me
Nic
SOURCE: NEED MANUAL
You can download the manual by clicking this link:
http://download3.msi.com/files/downloads/mnu_exe/M7104v1.0.zip
The connections for JFP1 and JFP2 are given on page 13 of this manual.
Hope this solves your problem. Thanks for using FixYa
Testimonial: "Thank you info was spot on and helpful"
SOURCE: how to conect front pannel (jfp1/jfp20)please....
Oh man, that's on old board. I looked for a manual, but the newest post of the book, was back in 2004, and the link isn't any good. But, when looking at the board, look at the lower right side of the board (as you look at it with the expansion slots to the left). You will see a row of double pins.
Usually, on the bottom of that row, there will be some writing that identifies the pins. The power switch pins are labeled PS and the reset is labeled RS or RST. The Hard Drive Lite is HDD,
Hope this helps.
Mark
Wiring diagram
