I turned off breaker and replaced bake element on my magic chef 6898VRV. When I turned breaker back on the stove doesn't work (black display). It is getting power since the clock and oven light will come on when I turn on a surface burner knob but no burner or oven will heat up. If I turn off surface burner knob the display goes black again.
It always came on fine after other repairs and power interruptions.
Is there some safe mode or reset?
SOURCE: magic chef stove
F1 means the computer has corrupted....... Part is probably around $150-200 Please rate my help solved as I solved your question.
SOURCE: have a magic chef oven, f1 display after self cleaning
Your sugestion does not work.I press CLEAR/OFF and power off several times, the F1 error and beeping is continue every 2 minutes. Any other suggestion?
SOURCE: pilot lights
you need to plug the oven in; pull it out and you should locate the pwr cord or you may already have it plugged in and have a breaker turned off or a gfi tripped
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
