Our KitchenAid Superba KEBC107, built in convection oven does not heat. The blower comes on, the oven light works, the display panel displays properly. When we turn on the oven, key in the temperature, and press ''start'' the fan kicks on, the control panel indicates that the oven is heating, but it does not heat. It will not heat in any mode--convection bake, regular bake, or convection roast.
We have checked and made sure that the control lock is not on, the timer is not on, and that the sabbath mode is disabled. We have checked to make sure the breaker switch was not tripped. Also have checked to make sure the heating element somehow did not become unplugged or dislodged.
Yesterday my wife put the oven in the self-clean mode and cleaned it. And two days ago we cooked a roast in it with no problems. We have not had a power outage or electrical storm.
I thought the same thing. i switched the working top element out to the bottom and same result (not working) the top one element (which was the bottom one) works fine. I got to get this fixed by Thanksgiving.I thought the same thing. i switched the working top element out to the bottom and same result (not working) the top one element (which was the bottom one) works fine. I got to get this fixed by Thanksgiving.
You can't post conmments that contain an email address.
This is what I used on my Kitchenaid Superba maybe it will work on yours also.
Hold the "oven light" then push the "CLEAN" button and then the "START" button. Wait until "Door Locked" shows on screen. Press "Cancel/Off" (Upper Oven) wait until "Door Locked" turns off. The oven F5 E1 is now fixed.
There is a fan for cooling down whole oven, it can turn on and off during the regular bake or broil cycle to cool down the oven on the outside. It's controlled by its own thermostat, so it will even stay on for awhile when you turn the bake off.
KitchenAid KEBC107KSS does not heat hot enough and does not heat evenly. When the temperature is dialed higher, it burns the cookies. When the convection fan is on, it has a 'cooling effect' so the temperature never reaches the proper level. Is this problem repairable? Or is this a thermostat issue? Thank you for your help!
There is a thermo fuse located behind the back panel of the oven. If the oven appears to be working but is not actually heating then this is the cause. The oven will have to be removed from the wall, power to the oven shut off at the main breaker and the back panel removed. the thermo fuse is just to the left and up from the center of the convection fan. It has 2 wires connected to it.
