It is a hayward swim pro sw256t series
SOURCE: Bought a new home with pool which has the Hayward
Need some more info on the Sand filter. I can help you out. With the rest. Is that the pic of the filter you have. If it is then its a top mount. Depending on the debri that comes into pool, you will back wash 1-2 times a week. After back washing you will turn to rinse and let it run for awhile (of course each time you turn the handle make sure the pump is OFF. Set, then turn on.) then back to filter.. Any Q's just hit me up buddy..
SOURCE: replaced sand now filter isnt working
if u used play sand, or any other type of sand thats NOT pool filter sand, that could be the problem. also if there is too much sand or too little sand that could also cause this.
SOURCE: Where can I get a seal for the flow valve on a
www.arrowmotor.net and use the contact button. You would likely want the rebuild kit that includes all the gaskets and o-rings.
Be sure to include the model number off the valve, which should have SP at the beginning.
SOURCE: How do I chabge the sand in my s-200 Hayward sand
take top off open bottom drain use a small wet vac hose to get as much out through top out be careful not to damage filter bars wash the rest out through bottom drain with a garden hose
SOURCE: stuck multivalve head handle
that means the filter is sendind sand back to the pool if it does the filter latteral must be replace . not a easy job
