Download the user manual to your TV. It has all details about how to set and release the parental lock. Click here to download the user manual. If you fail to unlock , you might have to get into its service menu options to release the password. To know more about this visit the site named 'Electro-help'. There is details about entering in to service mode, to most brands of TVs. Pull up older posts there. Check this link and select the site named above.
SOURCE: how to erase parental control code
I finally found out how to reset the V-chip password on this princess DT1350-P Tv. All you have to do is turn the TV on and turn to a channel that doesn't prompt the V-chip password (even if it's snowy) and hold down the volume (down -) button on the main unit while holding down the number "0" on the remote control. It might take a few tries, and you might need to change the TV channel for some reason but if done correctly, either the TV will turn off, or the menu screen will pop up and ask if you want to set the vchip password, either way you should be able to watch your TV now! :)
SOURCE: unlock codes
Found the code on another posting:
1,2,3,4
When the parental block comes up hit play, enter the code, then hit play again...
SOURCE: My Disney TV has a parental lock and I forgot the password
The parental lock code is 1369. I had the same problem and this worked for me. This for most disney tv's. If not let me know and I will continue to help.
