Need manual
Manuals may be downloaded using the provided links:
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
SOURCE: throttle cable for ryobi petrol blower vac
Most times you'll find that a universal cable from one of the dept. stores will work fine.If not the whole cable at least the thin insert can be cut to lenth and curled or l-shaped whit a pair of needle nose pliers. Dana
SOURCE: I have a 25cc Craftsman Blower/Vac
hi
if you have compression and spark(a blue one) try priming the engine,put some gas in the sparkplug hole and start the engine.if it fires only the gas you putted inside there is a delivery problem to find and fix(carburator and hoses.
bye
SOURCE: fuel lines replacement
The larger of the 2 lines is the pick up/filter line - the smaller is the primer feed line that goes to the pressure bubble...The fittings are different sizes so it should be simple. To test it , with the hose out of the tank..press the primer bubble...it will blow air out of the line...
SOURCE: Craftsman 25cc 2-Cycle Blower/Vac
Your engine is starving for fuel. Tyipically rebuilding the carb is a quick fix. If you can remove the carb and look at the face of it, you should see a brand and model #. Use this to purchase a carb kit with the needle and metering diaphram or have a mechanic rebuild the carb.
SOURCE: craftsman leaf blower wont start
The air gap for the ignition coil core to flywheel is adjustable on some engines and the gap does vary.
On a Stihl, I used a matchbook cover first, then doubled it and got the engine to start.
That amounts to 8-10/1000ths (0.008-0.010") as measured with a digital caliper after-the-fact.
I'm troubleshooting another engine currently from a McCulloch Airstream IV that only has ~12 hours and no spark but the coil measures roughly as it should; around 1K Ohms.
Was surprised to find the company went bankrupt in '99.
Another one killed by Asians and fairly poor design.
