Question about Lexmark X7170 All-In-One InkJet Printer
Right cartridge incorrect
My lexmark all in one is giving me a message saying right cartridge incorrect. Have checked it and it seems fine, any suggestions please?
  • 12 more comments
  • Anonymous Nov 09, 2007
    I wonder if it is down to lexmark putting a killer chip in the cartridges to prevent refilling. I am getting the msame message with left (black) cartridges
  • betty64 Nov 30, 2007
    It will not print and it says the right cartridge is incorrect
  • Anonymous Dec 01, 2007
    Hi there
    I just replaced both cartridges in my Lexmark X5470 and I am getting the error message "right cartridge incorrect". Both new cartridges are genuine Lexmark and I have managed to print in black and white only. I have followed the recommended Users guidelines to no avail. Any suggestions?
  • Anonymous Dec 11, 2007
    Have the same problem with the left cartridge. Unplugging both the brick and power to the brick didn't work.
    Does that leave the cartridge itself as the culprit? Another printer we worked on with this type of error had a button combination that reset this message.
  • Anonymous Dec 13, 2007
    Will never never never buy another Lexmark. Technical Support line has not solved my problem. I was reassured that if I purchased a new right cartridge that my problem would go away. It did...for one day! I have heard nothing but complaints from all of my co-workers about these all in one Lexmark machines.The strangest thing though is that I have the exact same model in my office at work and it has never caused any problems. I however cannot afford to waste money on yet another cartridge that might work for one day. The tech guy walked me through all the steps as posted on line and nother has worked. A piece of Junk
  • Anonymous Feb 09, 2008
    Yep, I have the same problem with both cartridges. Tried everything that Lexmark support recommend on there site, but I still have the same problem.
    What a pain, mines going back to PC World........
  • Zion880818 Feb 26, 2008
    i also having this problem, but my printer is X3350, after i replace black cartridge few day, it started prompt out Right Cartridge Incorrect, i went to lexmark web already, i follow what excatly lexmark web say, and i suspect is hardware issue, if i dont want send to service centre, i want repair by myself, can some one help me out? Thank you, hope you reply me as soon as you can, my email - isd@netlabs.com.my
  • ChrisG08 Jun 18, 2008
    I have the same problem.  At first just thought that the cartridge was out of ink and I was going to get a new color cartridge when got a chance (and could afford)...but after searching the "right cartridge incorrect" message on the internet, am now afraid that that is not the problem.  So far, my printer will not print at all, even with just the black (left) cartridge, which according to the system has plenty of ink left.  Can not afford to buy a new color cartridge to try in case this does not do anything to make the thing print.  Very frustrating!  (Can still at least scan.)
    Does anyone know of a way to at least be able to print in black and white when getting the "right cartridge incorrect" problem?  Thanks.
  • Anonymous Aug 06, 2008
    I have this problem and have just been able to get it to work with the black cartridge. I turned the printer off , removed the colour cartridge, switched it back on then just pressed select when it said the cartridge was missing and pressed continue on the error message on the computer screen.
  • Anonymous Aug 18, 2008
    I have the same error message after I have installed an original Lexmark black cartridge.
    I tried the solution suggested by Jazzer2007 and it worked..... Thank you so much!!!!
  • Anonymous Jan 08, 2009
    I removed the "brick" waited, reinserted, and the printer now won't power up.
  • Anonymous Apr 17, 2009
    Two in a row did this and Lexmark gives me the standard "We're so sorry to have an unhappy customer" BS, but has been no real help at all.
  • Anonymous May 05, 2009
    yes, same issue for me too!
  • honey
    honey Jan 30, 2018
    You can give a call to customer care no (877-330-0887)
This solution (RESET the BRICK - solution 1 above) worked for me!
I had a brand new out of the box Lexmark X4580 and after one or two prints I was suddenly getting a "Left Cartridge Incorrect" error showing on the Printer Control Panel and the printer would now all me to print anything.
After about an hour of trying this and that (cartridges in, out and shalen all about!) ; no avail, I tried this and hey presto, it worked.
When I removed the "Brick" power supply I left it until the Green LED had faded right out though, I dont know if that was significant or not. Fingers crossed all is sorted now!
Posted on Nov 05, 2007
  • Anonymous Nov 05, 2007
    I should also say that I saw many, many brands of printer, including Dell and HP with these issues as well and it looks like there is a common theme here. Who ever makes the hardware that is being used in these brands really needs to sort these issues out as I was about to take this printer back to the store in the morning and demand a refund.
    These glitches are VERY bad for business and in this day and age big companies should have these kinds of things ironed out way before the product hits the shelves!
    Novelist:
    Champion:
  • 202 Answers
Error: "Right Cartridge Incorrect" on a Lexmark X7170 All-In-One ID:ENUS24016 Cause The Right Cartridge Incorrect error message generally indicates a communication error between the All-In-One and the cartridge. This can be due to a faulty cartridge or to a simple interruption in the communication between the cartridge and the All-In-One. The procedures below will help you identify the cause and resolve the issue. Rebricking the All-In-One and Resetting the Factory Defaults NOTE: The embedded links lead to specific troubleshooting documents. Step Action 1 Power off the All-In-One and remove the power adapter (brick) from the back of the unit. Wait 20 seconds, reinsert the adapter, and power the unit on. Did the error message return? Yes: Continue to step 2. No: Print a test page. If the test page prints, the error is resolved. 2 Reset the All-In-One's factory defaults (click here for instructions). Did the error message return? Yes: Continue to Checking the Cartridges. No: Print a test page. If the test page prints, the error is resolved. Checking the Cartridges NOTE: The embedded links lead to specific troubleshooting documents. Step Action 1 Open the top cover of the All-In-One. Remove both cartridges. Close the top cover. 2 Power off the All-In-One and remove the power supply brick from the back of the unit. 3 Reinsert the power supply brick into the back of the All-In-One and power the unit back on. Does the error message reappear? Yes: Skip to Contacting Lexmark below. There is a hardware issue with your printer and you need to contact our technical support center. No: Continue to step 4. 4 Clean the cartridge contacts (click here for instructions) and the AIO carrier contacts (click here for instructions). Continue to step 5. 5 Power the AIO on, reinsert the black/photo cartridge, and close the top cover. Power the All-In-One off and then on again. Does the error message reappear? Yes: Power the unit off and try step 5 with another black/photo cartridge. If the error persists with the new cartridge, proceed to Contacting Lexmark. No: Continue to step 6. 6 Power the AIO on, reinsert the color cartridge, and close the top cover. Power the All-In-One off and then on again. Does the error message reappear? Yes: Power the unit off and try step 6 with another color cartridge. If the error persists with the new cartridge, proceed to Contacting Lexmark. No: Try printing a test page. If the test page prints, the error is resolved Contacting Lexmark Please contact Lexmark Technical Support for additional assistance. NOTE: When calling for service, you will need to know your printer model type and serial number. If you need help locating this information, click here. Please call from near the printer in case the technician asks you to perform a task involving the printer. Let me know what happens. Good Luck. Tim
Posted on Mar 15, 2007
  • Anonymous Mar 15, 2007
    http://support.lexmark.com/cgi-perl/know...
    here is tghe Lexmark site for your machine and any other info you may need.
    Tim
  • 3 Answers
When replacing a standard Colour cartrige 33, dont make the mistake of thinking that a photo colour cartridge 31 will do the trick, oh no, the photo clour sits in the black 32 spot next to the colour cartridge. otherwise you can get a right cartridge incorrect message.Then spend an hour onto Lexmark Tech support that havent a clue. Hope this helps someone.
Posted on Jun 09, 2008
I had this same problem and I have just discovered that there is a software fix on the lexmark website: http://support.lexmark.com/perl/support/support.cgi#
It's a "firmware update" I wish I knew this a month and two ink cartridges ago...
Posted on Jul 26, 2009
    New Friend:
Sadly, Lexmark is limiting the copies per cartridge. There are electronic means on the print head to derail you after a certain amount of copies per cartridge. The suggestions above work if the system "hiccups" and you are still in the usable count range.
Just Papa bear limiting how many warts can **** his puss.
Sincerely this is a sign of the "greedy" times.
Posted on Jan 23, 2010
  • l1u2k3y Dec 15, 2010
    1) refill #34, insert into printer X5495, printer shows "left cartridge incorrect".
    2) Tape one contact at left low corner, reinsert into printer, printer shows "left cartridge missing".
    3)On computer, find the printer, select properties, select advance, uncheck last 4 squares, check print directly to printer.
    4)print any white/black pages.
    It works!
  • nellieou Feb 10, 2011
    I tried the taping technqieu but can't get the printer to show "left cartridge missing". Maybe I'm not taping in the correct spots? This is so frustrating.
Posted on Aug 18, 2008
  • 3 Answers
Have you refilled this cartridge? I have the same problem and research shows that it could be that Lexmark deliberately program their printers to refuse a refilled cartridge!!!??? I have mailed Lexmark on this and am awaiting an answer...
Posted on Jul 14, 2009
    New Friend:
  • 4 Answers
Timothy's Step 1 worked for me! Thanks so much!!
Posted on Sep 09, 2014
Alswag, I tried your suggestion, and now I get an error msg when printing that says, "an unknown error occurred while printing".
And I don't remember which boxes were originally checked, that I UN-checked! HELP!
Posted on Feb 01, 2012
That info is not correct for the x7170. Here is the link for the correct info. http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:463:0:0&framed=&docid=ENUS24013&relevance=1
Posted on Jul 14, 2007
    New Friend:
A quick work-around to just get a document printed was to remove the printer thinks is incompatible.
Posted on May 05, 2010
6ya staff
SOURCE:
Ink cartridge error message says "incorrect" it's
Yes it normaly is. Refill cartridges are risky
Feb 14, 2011 | Lexmark X4650 InkJet Printer
I have a Lexmark X6170 and when I try to copy it says "error 50C cartridge error consult manual. I have changed the black cartridge but not the color I don't use color it was working fine . I can find my...
The error is telling you that the color or black cartridge is missing. It's not recognizing one of your cartridges, most probably the new black cartridge. Here's a link to the Lexmark website to guide you on what to do with that problem. http://bit.ly/bkCWPF
Mar 25, 2010 | Lexmark X6170 All-In-One InkJet Printer
MESSAGE SAYS RIGHT CARTRIDGE INCORRECT
Hello there:
what this is refering to is that the cartridge is either not the right one for the printer or the device is having a problem with that cartridge i would remove the cartridge and verify that it is the right one that goes in their and also since youare having the cartridge out i would clean out the contact area to get rid of the old ink that may be sitting on the contact areas ok
best regards Michael
Nov 23, 2009 | Lexmark X5470 All-In-One InkJet Printer
Installed a new Lexmark ink cart and got an incorrect message
take out the cartridge , turn off your printer and take out all the cables behind your printer and wait for 5 minutes and put everything back in.. if the same error shows.. im sorry but your printer needs to be replaced.
Aug 15, 2009 | Lexmark X2500 All-In-One InkJet Printer
Lexmark X4530 Incorrect Cartridges.
By any chance did you get these cartridges refilled? If so then you may be out of luck as I read that Lexmark chip their cartridges/printers to reject refilled cartridges. I have the same problem at the moment just with the right (colur) cartridge. The cartridge is an original refillable Lexmark (i.e. grey box) I got the cartridge refilled twice and it worked fine, but the third time no joy. Research indicate that Lexmark program their printers to reject cartridges refilled 3 times!!
Jul 07, 2009 | Lexmark X4530 InkJet Printer
Refilled cartridge , printer says right cartridge incorrect
Lexmark builds intelligence into their cartridges and printers to prevent the use of refilled cartridges.
Lexmark has never approved the use of anyone else's ink for their printers primarily because there is no way to prove the quality of the ink.
Please purchase a Lexmark cartridge.
May 09, 2009 | Lexmark X7350 All-In-One Printer
May I suggest that you list this under printers rather than typewriters.
DickyO
Sep 27, 2008 | Lexmark Wheelwriter 3500 Typewriter
If it says to check the right cartridge (Black), replace it with a brand new one or one you know is good.
Walgreens will test and refill your cartridge for ~$10.00 (black).
I have heard of new OEM HP cartridges being bad.
The printer checks the cartridge level sensor and the electrical stuff.
Apr 21, 2008 | HP PSC 2110 Color Printer
LEXMARK X5270
tried to install lexmark x5270 printer without the CD with no luck. need help rb
Jan 13, 2008 | Lexmark X5270 All-In-One InkJet Printer
Lexmark X7170 All-In-One InkJet Printer Logo
29,301 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
