Closed caption is on, screen is not the right format (heads are cut off). I can't program a remote to get me into the menu.
I just checked and your specific remote is available on eBay for between $15 and $35. Just search the model number.
If you don't like eBay then consider a Logitech Harmony remote. They are easy to program and they will have all the functionality of your original remote including menu functions. I have two Logitech Harmony One remotes and there isn't a single thing I can't do that the stock remotes can do better. They are sold at Amazon, Tigerdirect, Walmart, Bestbuy, and just about any other electronics store.
SOURCE: '42pf9630a 37 philips tv only displays menu
Check the software and if is not BX23U-1.5.0.0_03531 upgrade it by downloading the software onto a usb stick at www.p4c.phillips.com if that don't fix the issue replace the SSB part number 310432842611
SOURCE: removing closed captioning
Worked it out. The Direct TV remote has a yellow button and that did it. I don't know whether I had inadvertently programmed it that way but problem gone.
Thanks.
SOURCE: need codes for Philips flat screen TV model #27PT6441/37 in
U recieved the propeer code from a nother direcTV provideer in my area. It worked when others did not.
SOURCE: MENU KEEPS POPPING UP WHILE WATCHING A PROGRAM. I
It's a common problem with the software in the TV. Updating the latest software for the TV should fix the problem. Here's a link for the Philips web site to get the software upgrade.
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PF9630A/37&slg=en&scy=US&mid=Link_Software
