Question about Minolta DiALTA DI2510F All-In-One Laser Printer
MY Di2510f is jamming and throwing the code C004E can anyone tell me If I replace the fan will it continue to jam or will it stop the jamming?
  • 128 Answers
Replacing the fan will only help you with that error code c004e. The jamming will be an entirely separate issue. Where is the machine jamming? Fuser area? Cassettes? Document Feeder? Please clarify.
Posted on Jul 26, 2012
6ya staff
SOURCE:
Di2010f code C004E
Power unit cooling fan is bad or jammed with dust!. looking at the rear of the machine on the right side lower there is a vent. remove the back panel (will require removing the upper back panel also. There is a filter with that motor. it mite be jammed in the fan clean it and tape it to the metal cover or just remove it then will have to check on every once in while. That fan cools the Power supply inside the machine. Might be burn it out worse case the control board that controls it is bad.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 21, 2013 | Minolta DI-2010F Copier
I have a Hp LaserJet 2430tn and its telling me there's a jam in the back but when I open it i can't see a jam. does anyone know what could be wrong?
hi
if you have not replaced the maintenance kit (fuser + rollers) and the toners were replaced at least 2-3 times, its time for a fuser replacement
p/n you need is H3980-60001
Jan 16, 2012 | HP LaserJet 2430tn Printer
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
I had a paperjam and even after clearing the jam, it's still telling me that i need to clear it. I know there is nothing in there and have tried everything i know to do to clear out this message. Does...
1) try to unplug power cord
2) check sensor flapper in fixing assy
3) open close few times all doors
4) if that helped clean rollers pick up, feed, separation
5) if nothing helps call service because you have pcb error issues
6) if you do not want to call service - Throw it trough the window :-)
Hope that helped.
Jul 02, 2010 | Canon ImageCLASS MF4350d Laser All-in-One ...
Sharp AR-287 Copier Paper Jam
most copiers that have lcd screens, should you show you where the paper is. sometimes it may take getting down to look under a couple of guide plates. or just roll some of the rollers to get the paper to come out. all it takes a minute piece of paper to be sitting on a sensor for it to throw the paper jam message.
Apr 01, 2009 | Sharp AR-275 Copier
Paper Jam fault
there are sensors that tell the machine the paper is jammed us a q-tip to clean them, remove the toner cartridge and check under that area when cleaning the sensors.
Mar 16, 2009 | Samsung SCX-4521FG All-In-One Laser...
Huge paper jam ( piece of a checkbook)
Throw it out and buy a new one! staples won't replace this unit and your gonna have to take it apart and clean the gears.
Also tell your employees to stop reversing the drive gears with paper inside the bucket it only reverses the flow and jams the unit.
I would buy a cross cut shredder next time.
Hope that helps.
Jan 19, 2008 | Techko SH1524CP Shredder
Minolta di 251 srror code coo7o
That's a toner bottle motor failure code.
Check that the bottle isn't "jammed" into the machine and moves freely.
Jan 11, 2008 | Minolta DiALTA DI2510F All-In-One Laser...
Minolta DiALTA DI2510F All-In-One Laser Printer Logo
627 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
