I forgot the login password to my laptop
You can use Smartkey Windows Password Recovery to help you to unlock dell password, and see the detail direction from http://www.recoverlostpassword.com/products/windowspasswordrecovery.html
If you can tell me what the Os do you use, it could be must better.
On XP you can try this:
Boot computer and press Ctrl+Alt+Delete twice when you See Windows welcome screen / login screen. It'll show classic login box. Now type "Administrator" (without quotes) in username field and leave password field blank, press Enter and you should be able to login Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
On Win 7 or Vista:
Ctrl+Alt+Delete won't work, you have to use some windows password reset tool. I recommend Windows Password Reset.
Resource: http://www.windowspasswordreset.net
SOURCE: how can i unlock dell latitude d420 bios password
Clearing the CMOS will reset the password...
Take the button cell battery out for a few minutes, put it back in, and all settings, including the password, should go back to defaults.
Unfortunately it looks like your BIOS battery is under the keyboard...
Dell has got what looks like decent directions here, for getting at it:
http://support.dell.com/support/edocs/systems/latd420/en/SM_EN/coinbatt.htm#wp1123951
SOURCE: Forgot my password
when it starts up press f10 and go to safe mode and you could change it from there
SOURCE: reset my laptop user password
Go to safe mode to reset it?
star the PC and press F8 then go to :Administrator
then enter “net user "your user ID" 1234 /add”, then your user ID password is 1234.
or take a look at http://www.laptops-battery.co.uk/blog/hacking-ibm-thinkpad-bios-password
I think Hack Dell inspiron 1501 password is the same as the IBM.
SOURCE: Forgot login password & fingerprint swipe isn't working
There are a lot of Windows password revealers and crackers available, but I’ve found that Windows Password Recovery Tool is the most effective.:
it not only supports XP, 2000, and NT, I have personally tested it with Vista Home Premium and Ultimate. It works perfectly to reset any local user account to a blank password
You can use the ISO to burn a boot CD. Follow these instructions:
1. Download ISO file from http://www.windowspasswordsrecovery.com Windows Password Recovery Tool
2. Burn to a CD using a CD burning tool such as Nero or Roxio or MagicISO
3. Insert CD into drive and reboot.
4. You may have to select an option in the BIOS to get the computer to boot from the CD.
Booting up and clearing a password takes a minute or two works like a charm.
SOURCE: how do i unlock my dell laptop if i forgot my
Is it the BIOS password or Windows password you are trying to get past. You can remove the battery on the motherboard and leave it out for 24 hrs or more and it should clear the BIOS password. The battery is a small round one like in a watch and it keeps power to a chip so your system wont lose the date/time and BIOS information. If its the Windows password you will have to use the adminstrator options or reinstall Windows completely and setup new passwords, eMail me at [email protected] if you need more assistance.
