Most motors are warm to hot when running.
Is it getting so hot that the thermal overload is turning it off? If so the pump should restart once it
cools down.
If this is a new motor on an old pump (replacement) it is likely to be:
1.) Incorrect or loose wire connections.
2.) Low voltage supply (frequently caused by undersized wire).
3.) Lack of fresh air supply to motor due to clogged vents.
4.) Incorrect amperage of replacement motor.
SOURCE: I HAVE AO SMITH MOTOR BL6414 HOW DO I WIRER IT UP
The BL6414 motor is shaded pole and does not require a capacitor.
SOURCE: where to find replacement parts for AO smith pool pump motors
TRY YOUR LOCAL POOL PUMP MOTOR REPAIR GUY... NEW ARE HARD TO FIND AND CRAZZZY $$$ HE WILL HAVE GOOD USED PARTS CHEAP . IT'S THE GREEN THING TO DO. FIX -REPAIR.. GOOD FOR YOU, I'M PROUD OF YOU.. GOOD LUCK AND VOTE FOR ME...JAY
SOURCE: Need to replace pump Impeller on A.O. Smith
To get to the Impeller you need to remove a series of bolts, or a large clamp, that holds the two halves of the pump together. Once you do that, if their is a diffuser (housing that goes over the impeller), remove it. To remove the impeller, you need to lock the motor shaft. You can do this a couple different ways depending on the motor. There will either be a small cap that grants access to the motor shaft on the back of the motor, or you remove a larger housing that grants access to the wiring and other components in the back of the motor. If it's the small cap, then you can hold the shaft with a wrench. If it's the larger housing, then you can slip a wrench (probably 7/16") under the thermal overload switch and onto the shaft to lock it in place. Now you can unscrew the impeller. Check to see if the impeller has a screw in the center. If so remove this first. It will be reverse thread. The impeller should spin off counter clockwise. If the impeller is very tight, be careful not to damage it. If you don't have an impeller wrench, I strap wrench, or very large locking pliers with a rag around the impeller works well. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave a good thumb rating if you found this helpful. Thanks, and good Luck!
SOURCE: Leaky 4 HP hot tub pump seal AO SMITH motor, pump
If you have removed the impeller this is what you need.
Part number for your shaft seal is : 37400-0028s
Here is a link to the manual on how to install / remove this seal on this pump:
http://www.hottubs.com/content/pdf/Sta-Rite_Dura-Jet_S377(9-12-03).pdf
Refer to page 9.
This seal can be purchased anywhere on the internet. Just do a google search with only the part number. Many suppliers will come up. If you have trouble, I have a few and can make an E-bay sale for one.
Testimonial: "Thanks, and especially for the link to the manual. This is exactly what I needed. Mark"
