BURNING A ROAST IN 45 MINUTES HAVE TO SHUT OFF BREAKER AND WAIT FOR IT TO COOL BEFORE IT WILL OPEN SETTING OFF SMOKE DETECTOR
SOURCE: Oven burners won't shut off
Bat, your model number is right on accurate. Here's the scoop... the F3-E2 means the temp sensor inside the oven cavity needs replacing, but I doubt that your problem is the sensor. The problem is your "microcomputer". I call it an ERC for short. There are 3 separate circuits on your ERC; low voltage for your keypad, medium voltage for the mechanical relays and high voltage for you elements. When you program a cook time/temperature, the ERC translates this into medium voltage and activates the proper relay on the ERC (i.e... "bake", "bake w/ convection", etc...) to send high voltage to the proper component. All of that to say this, the relay on the board that activates the bake element is "welded" shut. When powered off, the relay won't open up! This will result in run-away temps. I've seen this before on Whirlpools. The ERC will have to be replaced, the part number is #8302994 and lists for ~$180.00 at your local appliance parts store. If you need assistance with the replacement procedure, post back. If you decide to get in there without posting back, DISCONNECT POWER AT THE BREAKER PRIOR TO ANY SERVICE.
SOURCE: Oven doesnt heat, after a few minutes displays error code F3 E2
F3 E2 USUALY IS THE SENSOR IN THE OVEN IF YOUR LUCKY YOU CAN REMOVE THE 2 SCREWS INSIDE AND PULL THE WIRES THROUGH. MAKE SURE YOU UNPLUG IT FIRST.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
SOURCE: Whirlpool accubake self clean oven. Error code(s) E2 - F3?
You can get all the codes here.
F3 E2
9
Bake range over temperature
At room temperature, sensor resistance should be 1K to 1.1K. If not, replace the sensor. If the sensor checks okay, replace the control.
http://www.repairclinic.com/0078.asp#Westinghouse
Good Luck and Please Rate FixYa!
SOURCE: E2- F3 Error code, what does that mean??
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven.
This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board.
If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe.
If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!^!^!
might be better to replace oven wife no longer trust it might burn house down
