Type the printer IP address into the address field of your Web browser. Note: If you do not know the IP address of the printer, then print a network setup page and locate the IP address in the TCP/IP section. Click Reports. The following reports may be viewed from the Embedded Web Server: Reports Device Statistics Device Settings Device Information Profiles List
Printer Server Setup Page
SOURCE: how to you print a configuration page on a Lexmark
hit the right arrow untill you see either utility or test menu..
in there you use the right arrow untill you see print menushis select
SOURCE: prints garbage
You have a software problem there. You can try and clear the print job in the computer but more than likely its already in the printer memory and is going to print until its finished. I think you're going to have to let it run until its finished then go back and make sure your computer malfunction is fixed before you try it again. I know its frustrating...but it will eventually stop. You might want to re feed the used paper unitl it does. I'd say turn it off and on...but I don't think that will clear the print job..and you've probably already tried that anyway.
SOURCE: I cannot stop my Lexmark E260dn from continuimg to
right click on the printer icon and hit delete all jobs.
SOURCE: Just installed new printer Lexmark
This light sequence means that the printer has a service error, and printing has stopped. Please Press Continue button (green button) twice to see the secondary code. The secondary error code will help locate the problem. Please take note which light will be flashing for this will reveal what problems you have on the printer. For further assistance, please contact Lexmark Technical Support.
SOURCE: Lexmark e260dn printer always prints
If printer is connected to network, separator sheet must be turned off. Please access the printer's web interface and click on configuration and click on finishing menu, select none for separator sheet and then click on submit.
Slow printing can happen for a number of different reasons. Lexmark printers are host-based printers.
Please try use the Post Script print driver or Host Based print driver. You may go support. lexmark.com to download this, or may also click the link http://bit.ly/pYTmwf
The computer can not detect the printer for a number of reasons and this can be resolve by check the connection between the printer and computer. Please make sure you are using the recommended USB or Ethernet cable (network connected). Check the cable connections to the printer to make sure they are secure. For more information, see the setup documentation that came with the printer.
If connected to a network, make sure that the printer is connected to the network. Print a network setup page and check that the status shows Connected. If the status is Not Connected, check the network cables, and then try printing the network setup page again. Contact your system support person to make sure the network is functioning correctly.
For further assistance, please call Lexmark Technical Support.
