SOURCE: baumatic oven not heating up. Grill and fan fine.
if it is the b180, the answer (having just fixed this) is really simple.
The coily bit is the oven element - it will have gone. A new one from eBay cost me about 6 quid.
[WHEN IT ARRIVES !]
Turn the power off.
Inside the oven use a philips screwdriver to remove the 4 screws (KEEP
THEM !)
You will see a coily thing and a fan.
You unscrew 3 more screws (2 on the left and 1 on the right).
(KEEP THESE TOO!)
now ... bit tricky, have the new one inside the oven and take each wire off one at a time and put it on the new element.
Screw it back on but DONT put the last panel back in.
Turn the oven on maximum for about 2 minutes and see it glow red.
Turn the oven off. Make a cup of tea and have a couple of biscuits while admiring how good you are and waiting for the element to cool down!!!
Put the final panel back in place. Whole thing (including a cup of tea) takes about half an hour.
SOURCE: indesit fde20 main oven wont heat up
sounds like the circular element at the back of oven has blown.
SOURCE: fan oven wont heat up
If fan is workintg, but no heat, then replace oven element.
If no heat or fan, then make sure timer is set on manual and not on auto
Please rate my solution.
Thanks.
SOURCE: Dead oven despite element replacement?
If it has a timer, then make sure it is set to manual, and not auto, otherwise the oven will not come on.
What usually happens is, if you have a power cut, or switch the oven off, then the timer automatially goes to auto when the power is on again.
Thankyou.
SOURCE: oven not heating up [fan works]
It wilbe a faulty oven element, you will need ti fit a new one.
It is located at the rear of the oven, behind a removeable cover.
Thankyou.
