a while? 1sec, 1min 1hr?
filter, packed,
where is gage sensor on rail.?
ever get a full tune up?:
the fsm is free here.
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
tj unlimited?
2 systems dead head or loop and is key to diagnosis.
looking now.,
49.2psi is spec, +-5 page 2 (so pump is good) but?/...
it is loop but no fuel pump reg at rail.
that is rail pressure not anywhere else.
at 44 you key off the pressure must hold for 1/2 min. or you fail
leak down test, (injector leaks or check ball in pump)
if the check ball fails it will take many key on to get full pressure
2 or 3 second pump runs, each key:?
see why?> unplug injectors see if leak down passes/?
all filters and socks in take, below pump
so it fails leakdown
the only way to find this is to block rail input. line,
if it still leaks tank drops
if it stops the injectors leak (for all those reasons)
the tank regulator has its own loop return feed back
so the rail really is a dead head, with one line there.
