NetGear WNR1000 Router Logo
Anonymous Posted on Jul 24, 2012
How to connect my iPad physically with the router
Anonymous
Level 1:
Scholar:
New Friend:
  • Contributor 26 Answers
  • Posted on Jul 24, 2012
Anonymous
Contributor
Level 1:
Scholar:
New Friend:
Answers
26
Questions
Helped
5293
Points
81
The iPad doesn't support Ethernet (aka wired) connections. It's Wifi or nothing. There are no adapters and the iPad has no way to handle this.
That being said there should be no need to connect the iPad to the router with an Ethernet cable. If you can't get a good signal, you either have to move closer to the router, buy a router with better range, or install range extenders/antennas.
  • Anonymous Jul 25, 2012
    I do receive wireless connection by simply turning on my router and my iPad 2.They are next to each other but the router does not give enough power to make the iPad receive enough bandwith. Is there a router and/or any range extender that you know of and recommend (of course not guaranteed!) Thanks.
    Personally I use three Cisco/Linksys E3000 Routers which I purchased refurbished from Amazon. They are all linked together and I have full signal everywhere in my house. Another option is to use a range extender such as the Netgear WN3000RP. I've never actually used this one before but it's easy and there is only minimal setup required. It will be compatible with your existing router because it's a Netgear product.
3answers
My IPAD 2 will not connect to the internet, ir picks up the router but will not communicate
In settings go to reset, network settings.. Make sure your router IP leases rent all assigned, set them for a 24 hour lease time.
reset your router with a 30 second unplug. imthemobile guru
I need a password to reach the interneton my ipad...it asks for a cisco password
If your wireless router was setup using the default configuration, the password, also called a security key should be on the bottom of the router. Alternatively you should be able to specify on your ipad that you want to connect using WPS, and your router will have a WPS button on it. Pushing it for 2-3 seconds would allow your ipad to connect without needing the password. You should be able to google "connecting ipad to wifi using WPS" and if necessary include your router model to get specifics about the location of the WPS button on your router.
1helpful
Netgear cant connect to ipad
I think you should check the wireless settings of the router netgear router and the iPad .
Do you have any other wireless computer or device in the network?
Can you connect any other computer or device to the wireless network?
If your wireless network is secured then make sure that you have the correct network key.
See the links below:
Netgear router setup
How to connect iPad to Wireless network
Can't connect my Belkin F5D7234-4 v4 to my ipad
This link is for Iphone repair, It solved some of my Ipad problems. Hope it works out for you
1helpful
How do you set up a secured home router to an iPad2? Having a problem accessing my Belkin router with my iPad2. The iPad keeps asking me for a password which I don't ever recall setting up. There is...
Your iPAd should see your wireless network like other devices do. Does your iPad not prompt you to connect to your home network? If it does you should enter your wireless pass key manually on your iPad.
I have a Netgear router Model # WGR614 v7. The new Ipad cannot connect unless I tell it to forget that netwok, then reset network settings. I then unplug the router, leave it a minute or two & then...
What version of iOS is the iPad running? Try updating the iPad to the latest version of iOS (4.3.1) and see if the wireless situation is better.
To update the iOS, just plug the iPad into you computer and look in iTunes to see if an update is available for the iPad.
1helpful
Why do I have to frequently turn on/off to reset to get Internet access. I have to do this almost every day for my iPad. I still am connected wirelessly but no Internet connection. I've had many wireless...
Try setting the channel of the router to another one, like 11. The default channel competes with land line wireless phones, yours or your neighbor. Resetting to higher channel usually does it. I have included the highlights of what SHOULD be set in a router.
Wireless Router
It is usually easiest to run the install wizard, but be sure to be ready to set the items listed below.
Things to set:
Note: Routers are intended to be set by geeks. You have to SAVE EVERY page, or the changes will be lost. A geek knows this (apparently). The router gives no protest...just dumps your changes.
1. Login password (RECORD THIS!!). Consider taping to bottom of the router. Physical access is not the security issue.
2. Set a recognizable system ID.
3. Invoke wireless security of at least WEP.
a. Assign your own access code, 10 digit home or cell #. Consider taping to bottom of the router. Physical access is not the security issue.
4. Check that your router is set to broadcast its' presence.
I have a WZR-HP-G300NH router and am having trouble connect my ipad to it. Ipad is asking for a pass word. How do I fix it?
I recently got this router and had trouble keeping a wireless connection to my ipad. On the router, I set up security with wpa2/psk and set a password and was able to enter that password on the ipad and got a connection but only briefly. After repeated losses of connection, I took encryption off and now it works fine. This is a terrible solution though and eventually want to get encryption back on .
1helpful
My linksys router will now allow my Ipad to connect. The ipad does connect to other routers execept mine
usually with the IPAD. You need to put the correct settings into the wireless connection settings.
You wll need your SSID (the name your router shows up as when you search for wireless connections)
Your security type ( WEP or WPA/WPA2)
your wifi password.
I have connected many IPADS, as long as you have the correct details it should work
Are you setting the correct security type?
Top NetGear Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
