Kyocera FS-2000D Laser Printer Logo
amber nclea Posted on Mar 16, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
KYOCERA FS2000D ecosys laser printer. I replaced the toner as per instructions. First print had a vertical line down right margin of page. So googled if I should be cleaning anything because it does not say much on the toner instructions iro cleaning. Cleaned the metal roller with a dry lint free cloth. Still no change. Then had a look at the toner cartridge and (stupidly) turned it upside down. Toner powder escaped (not anywhere near printer). Cleaned up the toner cartridge but when printing I have a couple of dashes down the page - obviously toner that got in somewhere that its not supposed to be! sigh. Lots of wiping later I managed to reduce the 4 dashes to one dash printing down the page. Is it possible that this dash is toner that is 'in' the printer and not on the toner cartridge?
Mike Lyste
Level 2:
Champion:
  • Kyocera Expert 250 Answers
  • Posted on Sep 08, 2017
Mike Lyste
Kyocera Expert
Level 2:
Champion:
Answers
250
Questions
Helped
200749
Points
346
Its probably on the developer roller look at it as you spin the roller you should see a darker than normal area wipe the roller with a dry cloth until you no longer see it if you are turning it the right way no toner will come out the roller will have a thin even coating of toner on it or try cleaning the charge roller on top of the drum unit it should be 1 of the 2 these machines need to have the oem toner
5 Related Answers
rmclean103
  • Posted on Dec 04, 2008
SOURCE: black line on prints from Kyocera fs2000d
remove the drum by opening the LHS of the printer & removing the toner waste bottle, then depress the grey button on the drum assembly & firmly pull the assembly out. Best done in a darkish room as the drum is light sensitive.
The black line couldn't be fixed as it is caused by a scratch less that 2mm long on the drum. Ether a new drun at £299 or a new printer ar £245..
Anonymous
  • 2120 Answers
  • Posted on Jan 17, 2009
SOURCE: printing all pages as black
Open up the left side door and push in all of the chargers to make sure they are seated.
Sanath Kumar V
  • 684 Answers
  • Posted on Feb 16, 2009
SOURCE: Kyocera FS-2000D is printing a grey stripe down the side of page
In this case what i would request u to do is.......
Take out both the catridges from the Printer.........
Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry...........
Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out.......
Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds......
Now remove it and see whether u see any ink on the paper towel..........
U should see some ink on it now place the dry paper towel on the ink catridge in the same way........
Now do the same procedure again..........
Do the same procedure twice on the Black Catridge.................
Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel..........
Know insert both the catridges inside the Printer...........
Good Luck
Anonymous
  • 622 Answers
  • Posted on Dec 24, 2009
SOURCE: Kyocera FS-3900 and FS-4000 Prints very faint. New printers affected
sounds good
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Anonymous
  • 62 Answers
  • Posted on Feb 01, 2010
SOURCE: Kyocera laser printer toner refill
refill...uh oh probably wouldnt try it..there's is like only 1 company that does kyocera refill toners.....call KATUN... you can try to find that on the internet..you most likely willl have to buy actuall kyocera toner..
Tray 2 wont print kyocera fs2000d
you have to go into the print driver settings and tell the driver that tray 2 is installed. kyocera support website can help with instructions for print drivers
2helpful
HOW DO I CLEAN MY KYOCERA FS-2020 ECOSYS MONOCHROME LASER 35 PPM
Cleaning the Printer
To avoid print quality problems, the interior of the printer must be
cleaned with every toner container replacement.
1 Open the top cover and MP tray.
2 Lift the developer unit together with the toner container out of the
printer.
3 Use a lint free cloth to clean dust and dirt away from the registration
roller (metal).
4 Insert the developer unit together with the toner container, back into
the machine.
5 Close the top cover and MP tray.
6 Open the left cover. Use a lint free cloth to clean dust and dirt away
from the vents.
7 Close the left cover.
8 Use a lint free cloth to clean dust and dirt away from the vent on the
right side of the machine.
I hope this is helpful,
Shawn
1helpful
A black line is printing 6.5cm from the right side of the page
Clean the main charge, this is a step that is suppose to be done when replacing the toner but most people don't. The instructions to do this is in your users manual. If you dont have the manual go to www.gfbm.net to download one. Also make sure the cleaner is placed all the way back to the right when done or it will effect your prints.
1helpful
Kyocera FS2000D. Paper jam reported occassionally
this is problem with sensor you have to check all the sensors like
registration sensor
duplex jam sensor
paper exit sensor
face down tray paper full sensor........
easy way to solve this problem is remove Durmunit and toner box and rear unit then clean it useing a blower and refix all the componet and try...........
1helpful
2answers
Far right side of the text or picture missing on Dell 3100cn.
Refer to the following table
Cause
Solution
How common*
Contamination in the laser path
1. Clean the laser path. (Remove the laser/scanner assembly and clean the lens.) 2. Replace the laser/scanner assembly
8
Defective fuser.
Replace the fuser assembly
Lack of toner or faulty toner cartridge.
Redistribute the toner in the toner cartridge. If the problem continues, replace the toner cartridge.
7
4helpful
Printing all pages as black
Black line on prints from Kyocera fs2000d
2helpful
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
2answers
Yellow line on edge of page
on a ricoh - that would be the pcm - photoconductor module on an ecosys the module should last 100,000 pages nothing ever seems to last that long send an email to http://www.pcandl.com/ or call where you bought it
Top Kyocera Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
