Printer goes through stages of printing, tells the computer what percentage of document has been printed, but nothing is actually printed. I get a totally blank sheet of paper. I am writing a research paper and need HELP to print it. I am assuming that this service is free; otherwise, I cannot use it.
The Z715 needs a #50 black ink cartridge and a working color cartridge to print. To check if there ios ink coming out of your black or color cartridge touch the bottom of it to a paper towel and if you see a solid black blob or 3 blobs of Yellow, blue and red for the color then your problem is else where. If U are printing stuff from the internet sometimes the printer will try to use the color cartridge to print this so even though the black is working it comes out blank if the color is dry
SOURCE: Nothing printed when paper goes through printer
the ink nozzles on the cartridges are clogged. first try cleaning them using a alcohol-soaked Q-tip against the shiny part where ink comes out (remove cartridges first). if still no ink, cartridges may be out of ink, so either replace or re-fill them.
SOURCE: installment of lexmark Z715 printer
Here is a link for the download page for the drivers. Just enter the model # which is Z715 and select your OS and you can start you reinstall: http://downloads.lexmark.com/perl/downloads/downloads.cgi
SOURCE: LEXMARK Z715 will only print in yellow and both black and color cartridges are half full.
Clogged, or dirty plunger in this units printhead.. You need to check and clear the clogged unit.. Tihs printer is going to need service..
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: Lexmark Z715 printer feed paper
The feed rollers might be dirty from the ink. Try cleaning them with a Q-TIP with a little isopropyl alcohol.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Hi aparker53, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
Does the ink print head move while it tries to print ?
Is there ink in the printer ?
Did ink cartridge need plastic seal of some kind to be removed ?
Try cleaning printer head in printer properties on p.c ?
