Philips DECT 2252S Cordless Phone Logo
Posted on Dec 13, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Philips dect 122
It shows unregistered after trying to register it also
Anonymous
Level 2:
  • Expert 71 Answers
  • Posted on Jan 21, 2009
Anonymous
Expert
Level 2:
Answers
71
Questions
0
Helped
27866
Points
178
Normally , one base can register 4 hanset in EEPROM setting. The model, Maybe you can try press the "page" key, then plug the power cord , after 5 to 6 second , release "page" key. Try to register handset again.
8helpful
On the screen of the phone says not registered and wont allow me to make phone calls or recieve
Please try the following procedure to register the handset:
  1. Place the unregistered handset in the telephone base. If PRESS FIND HS 4 SEC ON BASE does not appear on the handset screen after a few seconds, remove the handset and place it in the telephone base again.
  2. On the telephone base, press and hold FIND HANDSET for about four seconds (until the red IN USE light on the telephone base turns on) and then release the button. The handset shows PLEASE WAIT... and it takes up to 60 seconds to complete the registration. The handset shows HANDSET X REGISTERED (X represents the handset number assigned) and you hear a beep when the registration completes.
When the registration is complete, the newly registered handset is assigned the next available handset registration number. For instance, if you already have HANDSET 1 and HANDSET 2, the next registered handset will be HANDSET 3
9helpful
Warning sign on the display, what shall I do?
try take out batteries.when you put them back for a short period its flashing "anmelden" or "searching",in tnis short time you can accses the menu and try to reset the handset.
2answers
Philips CD245 Cordless Twin
just one phone displaying unregistered
Philips dect 122
During a call, press the top right button to turn mute off
Manual
1helpful
Philips dect245 searching problem
1. try to reset handset. try sw reset in the manual .
2. try to clear the base. unplug power cord, press and hold "page " key , and plug the power cord , after 5 to 6 second release page key.
3. Register again.
4. If there is still searching , open the base and handset, to check ,if the antenna is broken or not.
1helpful
Phillips dect2152
If you bought the base and handset together they should already be registered. If not then the instruction manual is downloadable here: MANUAL
The relevant section is on page 16 - here is a copy:
4 handsets can be registered to the base station. A handset
can only be associated with 1 base station.
�� To register another handset
First enter registration mode by unplugging and
plugging back in the power adapter to the
electricity supply.
Handsets registering / unregistering ( )
�� To unregister the handset you use
enter the RC code*
�� To unregister all the handsets (except the handset you are using)
enter the RC code*
Once the menu is selected, enter the RC* code written under the base and press
to confirm.
Warning : If you wish to associate a non-Philips handset to the DECT 211 or DECT 215 base
stations, make sure that these handsets are GAP compliant otherwise they will not operate properly.
*RC code
(Registration
Code) is
written under
the base.
Warning : Once unregistered, the handset is no longer operational.
Please rate my assistance this should be a fixya!
Philips Dect phone 122
It's a while since you posted, but find your exact model number (under the basestation) then go to:
http://www.support.philips.com/support/html/index_gb_en.html#../~scripts/xsltransformsearch.asp?url=http://www.sms.philips.com/catalogue/list?sid=SMS||type=CONSUMER||locale=gb_en||mode=prod_text||item=dect%20122||page=1||show=50&xsl=search_result.xsl
You'll find the English PDF file from the list!
4helpful
Philips cordless phone DECT 122
Can you guy try to reset handset from menu.
Top Philips Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
