75% of the screen has gone very dim, and the rest of the screen is completely black. The portion of the screen that is black is the upper right. When you turn the TV on almost the entire right half of the screen is black and as it warms up it starts to provide more of an image, but it never gets to the point where the whole screen is not black.
SOURCE: Toshiba 50HP66 50 in No Picture/Only Sound
Most likely a power supply failure, and or a failure on one of the other boards that is causing the shutdown.
The set will need service.
Jerry G.
SOURCE: Toshiba Regza 46 flat screen LCD 2 years old that
I'm having the same problem!!! Could use some help!!
SOURCE: Dear FixYa, I own a 3 year old TV which has an
convergence failure, parts need to be replaced controling the crts
then focused and it will be as good as new.
ON THE SAME DAY OF 12/13/2008 OUR TV DID THE SAME THING. ON THE LEFT HAND CORNER OF OUR SCREEN THERE IS A BLACK FUZZINESS TO IT. WHEN TURNING THE TV ON IT TAKES A FEW MINUTES TO WARM THE COLOR BACK UP BUT THE ORGINIAL COLOR. NOT SURE ON WHAT HAPPEN TO IT.
ON 12/13/2008 WE ALSO HAD THE SAME PROBLEM. ON THE LEFT HAND PART OF THE SCREEN THERE IS A BLACK FUZZIENESS TO IT AND IT TAKES A FEW SECONDS FOR THE REST OF THE COLOR TO COME IT. BUT, IT STILL HAS A DIMMINESS TO IT WHEN YOU ARE WATCHING IT. WHAT COULD HAVE CAUSED THIS ISSUE TO THE SAME TELEVISION ON THE SAME DAY. HOW UNUSUAL??
Mi televisor es una sanyo de 42 pulgadas,y hace dos semanas de repente se puso la mitad de la pantalla en negro (parte de abajo) y en la parte superior si tenia imagen y sonido, pero eso era momentaneo (diez segundos) y despues volvia a abrirse normalmente la imagen, y hace un semana que de repente volvio a hacer lo mismo pero en forma completa, es decir, se puso totalmente la pantalla negra pero si tiene sonido (se escucha cuando cambia de canal y sube el volumen) necesito ayuda, que puedo hacer!!!!!!!!!!!!!!!!!!!!!!!!!
