Ac not cooling,freon ok,compressor runs,blows hot air.
I would check the low and high readings with a gauge set first.
Its possible the compressor has failed internally.
If the orifice is plugged up one of the lines should be cold where the freon gas is concentrated.
The fan clutch is working ok, right ?
I'm showing an orifice tube in the front and an expansion valve in the back, so its doubtful both would fail at the same time.
SOURCE: 2002 GMC Savana 2500 Front AC warm, rear AC cool/cold
Typical symptoms of being a little low on refrigerant.
SOURCE: 2002 grand prix heater blows hot, compressor runs
you have a plugged dryer and capilary tube you need to replace bothto be able to recharge.
SOURCE: REAR A/C NOT BLOWING COLD ON 1997 CHEVY VENTURE VAN
It is the expansion valve. It is in the rear behind the left rear tire. It is gold in color and in route with the ac lines. Guaranteed fix.
Good luck
SOURCE: 04 Saturn Vue AC blows cool air for about one minute then hot air
Above solution is correct, had the same problem with mine and it was the expansion valve.
