Are you trying to boot the computer through a CD or floppy disk? If not then you have a hard drive problem. I/O errors are caused by a "Non readable disk"
SOURCE: Error Message on boot
IBM requires using a "branded" network adapter, meaning one that has IBM's name on it, no matter if it's broadcom,etc. There is a couple of workarounds for this problem which would enable you to use whatever wireless adapter you wish. I would google IBM R40, and error 1802 and you'll find the application you need. Unfortunately, I'm not able to offer it to you here.
Good luck
SOURCE: Recovery Disk can not recover system
It could be a hard drive crash. Can you refort the hard drive and see if you get any errors.
Check to see if you have any scratched on the CD.
SOURCE: windows Error Recovery - ''an unexpected I/O error occured''
Hi
This seems to be serious problem. Please share the exact error message. If there are any external devices connected to the system please remove and then try to boot the system again.
Also post the brand and model of your laptop so that we can be more specific in terms of the steps.
Thank you
Rakesh
Dell Expert.
SOURCE: Windows Boot Manager error
Here are some great source where will will get any kinds of HP,ACER,DELL and COMPAQ laptop Solution and any kinds of Driver download.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
kapena84
SOURCE: My EEE PC1015 PE keeps giving error message
in situations like this you just must download the correct manual and reinstall the OS,if you have no disk choose a different OS some are virtually cost-free
Computer is booting from a non-bootable source
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette
or CD is in the computer, unless you are attempting to boot from a diskette.
Note: This error has also been known to occur when a
memory stick is in a card reader and the computer is attempting to boot from it.
If you have any card reader or flash reader make sure that no memory
stick is inside the computer. Additionally disconnect all USB drives, cameras,
ipods, iphones, etc. from the computer.
If you are attempting to boot
from a floppy diskette and are receiving this error message it is
likely that the diskette does not have all the necessary files
or is corrupt.
If you are attempting to install
Windows XP or Windows 2000 and are receiving this error message as the
computer is booting verify that your computer BIOS
has the proper boot settings. For example, if you are attempting to run
the install from the CD-ROM make sure the CD-ROM is the first boot
device, and not the hard disk drive.
Second, when the computer is booting you should receive the below prompt.
Press any key to boot from the CD
Important: When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again.
Note:
If you are not receiving the above message and your BIOS boot options
are set properly it's also possible that your CD-ROM drive may not be
booting from the CD-ROM properly. Verify the jumpers are set properly on
the CD-ROM drive.
Computer hard disk drive is not properly setup in BIOS
Verify that your computer hard disk drive is properly setup in the
CMOS setup. Improper settings can cause this
error.
Corrupt NTLDR
or NTDETECT.COM file
