I saw another tv that was doing this, the light blinking seven times, was that yours? it ended up being a bad Ysus board and Buffers.I saw another tv that was doing this, the light blinking seven times, was that yours? it ended up being a bad Ysus board and Buffers.
You can't post conmments that contain an email address.
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Have you tried plugging it in without the surge protector? I would wager that either a) the surge protector needs to be reset/turned on and off depending on the model or b) either your TV and/or surge protector have been damaged by the power surge.
Try plugging the TV straight into the outlet and see if that helps.
i have the same thing but what i do is unplug the tv and plug again till i hear a click then replug immediately and wait for the tv to come on .this is normally a symptom of a weak surge protector in the back, inside of the tv.it is normally not an expensive repair and better still if the tv is still on gaurantee it should cost nothing.
Check your power connection and the cable going into the TV. Also, if it is plugged into a surge protector, test to make sure the surge protector is working and that it hasn't tripped. If it is getting power, but it still refuses to turn on, take it to a tv repair shop for repairs.
I suggest you unplug the set for about 15 minutes and then plug it in and try again. Sounds like you may have had a power surge/bump in the middle of the night. Althoguh you are using a surge protector, doesn'r mean the devise hooked to it can't lock up during a power surge.( Surge Protectors are an insurance policy only, not a garrentee ). If unplugging the set and waiting doesn't fix it, it will need to have the power supply section of the board repaired. Good Luck
Ed
NC Electronic
Mills, Wyoming
th42pz700u
