My F0 Sole Treadmill worked fine. I turned on today and the control panel lights up but nothing I press works. I unplugged the unit, I checked all connections, and pulled out connections and re-connected but it keeps doing the same. Speaker works, fan works but none of the speed,incline, workout buttons, enter, start, etc.
SOURCE: belt wont start on a brand new Sole F80. Motor
It sound like the motor control board is the culprit. Unplug unit then remove shroud then find the 2 leads that connects the motor to the motor control board disconnect them then plug in unit and see if the display blackout after programing the display then hitting start.
SOURCE: my sole f83 treadmill is
Hello there,
When the treadmill remains in 0% incline and then comes up with a message showing elevation error, it is quite clear that there is a problem with the treadmill and the problem is related with the mechanism that controls the elevation of the treadmill.
The mechanism responsible for the elevation of the treadmill is some hinges that are located in the lower front part of the treadmill. They are weak and cannot lift up the treadmill anymore.
The solution is for you to have them replaced, then you turn on the treadmill, then you press the incline control key and it will increase in % this time.
Hope this helped.
Goodluck
Elect_Comp
Double check that all connections are secure, especially the console cable. Unplug and reconnect the console cable to verify.
Make sure the console cable is not pinched or damaged in any way.
Turn the power off, unplug the power cable and wait 60 seconds. Remove the motor cover. Wait until all red LED lights have gone off on the motor control board before proceeding. Next, verify that none of the wires connected to the lower board are loose or disconnected.
