Belkin (F5D5231-4) Router Logo
Posted on Oct 31, 2017
Belkin - N1 Vision Router Unable to connect to the interste
I have just bought a Belkin N1 Router but I am unable to connect to the internet. I have wireless internet through cirrus communications however I am still unable to contact to the internet even when I select static IP.
Can anyone help before I take this stupid thing back???
Many thanks
Donna
  • Anonymous Dec 22, 2008
    My problem is similar. I also have wireless through my carrier, but the installation CD will not install
Ron Houghton
Level 1:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 10 Answers
  • Posted on Nov 01, 2017
Ron Houghton
Contributor
Level 1:
New Friend:
Night Owl:
Answers
10
Questions
0
Helped
991
Points
28
Did you use the pass key to connect? If you are using the wifi you have to go to here 192.168.1.1 with browser type admin for username and admin for pass and config the the router. To make life easy just use a cable ie Ethernet..
5 Related Answers
Anonymous
  • 17 Answers
  • Posted on Nov 09, 2007
SOURCE: Belkin N1 Router connection drops when phone rings
You may have a phone line connected from the modem to a wall outlet. Count the number of cables coming out of your modem - you should have only three: the power cable (connects to the wall), Cat 5 (also connects to the wall), and ethernet (running from the modem to the router).
Anonymous
  • Posted on Jan 29, 2008
SOURCE: Nortel IPSEC VPN unable to connect via a Belkin N1 Wireless Router
Belkin says IPSec pass thru works now. I'll know tomorrow.
http://www.belkin.com/contact/milan/default1.aspx?id=580959590B0A5E0C0B5A59575B595F0A305F5D
F5D8231-4 WW v4.00.18
http://www.belkin.com/contact/milan/filedownload.aspx?id=580959590B0A5E0C0B5A59575B595F0A305F5D&file=0
Anonymous
  • Posted on May 25, 2008
SOURCE: Belkin N1 Vision
DHCP Host name is what your looking for.
you need to name each item ie. psp as psp and ps3 as ps3 when you setup each item for connection. so when you setup or edit the settings for your ps3 on your ps3 you need to look for DHCP Host name and name it ps3. etc
do the same for all.
kakee
Michael Galve
  • 1269 Answers
  • Posted on Apr 01, 2009
SOURCE: Can I use my belkin N1 Vision as a bridge?
It can't be used as a bridge but you can use it as an Access Point. All you need to do is disable the DHCP server of the router and don't use the Internet/WAN port
kakee
Michael Galve
  • 1269 Answers
  • Posted on Jun 30, 2009
SOURCE: F5D8233-4v3 - Belkin Wireless Router
You must configure the wireless settings of the laptop manually. It should match the wireless settings of your router. If you have wireless encryption enabled, make sure to type the network key on the wireless settings of your laptop.
My internet is greatly reduced with Belkin N1 vision wireless (before the hook-up it was 15mbps now only 5mbps), I have tested by hooking directly from the modem to the computer and got 15mbps. Before N1,...
When you only get 5 mbps are you connecting to the new router wirelessly or via the ethernet cable? If it is wirelessly then try connecting with an ethernet cable and see if you still get 5 mbps. If so then try resetting the router (the procedures for this will be explained in the manual) and re-test. Wireless connections can slow down due to obstacles such as thick walls or other obstacles of that type. If all else fails return the unit and try another.
My belkin vision n1 loses connection, how can I prevent this happening
Hi .....
I got your issue .....
Try with the following steps ....
Step 1: Connect modem>>router>>computer
Step 2: Opened the internet explorer
Step 3: On the address bar type http://192.168.2.1
Step 4: you will get a router page
Step 5: Towards the left column below wireless click on channel and ssid
Step 6: Change the channel to 11 and then click on apply changes
Step 7: Then close the screen and check with the connection
If you have any issues contact the toll free belkin technical support 1802235546
Thanks .....
With regards....
Priya
Signal problem
Step 1: Connect Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer (You can use any Web browser )
Step 3:On the left, under wireless click on channel and SSID (leave the password Blank and click submit )
Step 4: Change the Wireless Channel to 6 ( If its already 6 change it to 11)
Step 5: Click apply changes
Step 6: unplug the Router
Step 7: Restart the Computer
Step 8: Plug the power Cable back to the Belkin
Step 9: Connect to your wireless network
N1 Vision Router: i cannot connect to my belkin router...
Check the routers gateway IP address is in the same subnet as the other computers or laptop.
Ie 192.168.1.X . (X is between 1 and 254)
In addition, the sub net mask is 255.255.255.0
If all is ok then it is probably a miss configuration with WPA /WEP options
N1 Vision keeps losing internet connection from modem.
Hi Friend,
Please check it by updating the Firmware for your router from the below website
www.belkin.com/support
Regards,
Aysaam
2answers
My belkin N1 vision, keep disconnecting from internet. my landline pc works fine. i am only having the problem when connecting with my laptop. i am using a mac book pro with mac os x latest edition. thanks
My N1 Vision does the same thing, If you turn off the guest account, you should find its ok. Only when this Guest account is on, thats when it disconnects. Hope this helps. John
My Belkin n1 router disconnects from telstra every 2 hours - exac
This is a known problem with the Belkin N1 Vision Modem Router. The router keeps time by connecting to a Simple Network Time Protocol (SNTP) server every 2 hours. The solution is to go to www.belkin.com and download and install the pre-release firmware which is supposed to fix "A problem where the router could drop some connections on 2-hour intervals" among other things.
1helpful
Extend the range of my N1 router - how?
I have 2 x Belkin N1 vision dsl (cable) routers. One is connected fine with Virgin 20 meg broadband. Is it possible to use the other N1 vision router as a range extender up stairs to get better signal , without using any cat5 cabling ? I.e router-to-router
2answers
Belkin N1 wireless network not working
It might be an idea to upgrade the firmware which can be downloaded from manufacturers' website
Belkin N1 Vision - unable to see networked printers
Go on the main PC and Press Start, Control Panel, Printers and Faxes, Right-Click On The Printer You Want To Share, Properties, Sharing...
... If it comes up ( If it doesn't skip to the next part )...
49a8fc3.jpg ... Click on "If you understand the security risks but..."
Click On...
Click Share this Printer, Apply, Ok. Now look on your laptop for network places and you will see the printer on the network.
If you need to contact me email [email protected]
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
