I fixed a similar problem I was having. It requires a little work.
Take out the four screws from under the broken speaker. Carefully remove the cover, separating the speaker from the base. The two are wired together so don't pull them apart with force. Then remove the single screw, which is much larger the the previous four, and separate the speaker from the top cover.
If you chose you can remove the wires from the speaker, they just snap on, but its not required.
What I found is the speaker issue is not with the wire or the power, but the speaker it's self. On the back there is a big round metal piece. On my speaker that piece was pushed towards the front of the speaker. When I looked at the good speaker, that big piece was all the way back. So I simply pulled it back and presto, instant fix!
What you'll actually need in order to get Sirius is a satellite specific receiver (the JBL SIR 2.5 Satellite Receiver). That should come with the antenna you need.
Bit late! Just remove the four rubber feet underneath (self adhesive). Take out the four philips screws. It's a bit of a mess inside - you'll have to remove the connectors and some screws to get to the i-pod connector. You dont need to remove the button pcbs just the main board. The i-pod connector pcb is on the end of the grey ribbon cable connected to the main board (the button end of the unit).
the red and white x indicates that your speaker is in mute mode. you just have to click that speaker icon and uncheck the mute. then you'll hear a music thats for sure.
