Canon Rebel XT / EOS 350D Digital Camera Logo
Tim Hagan Posted on Mar 10, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Flashing LCD PANEL and won't take pictures
Hi there Whenever I turn my camera on the LCD panel turns off, then comes back and flashes (or more so 'stutters'), I can't take any photos or view my LCD monitor! What can I do?
Anonymous
Level 3:
Genius:
  • Master 2,985 Answers
  • Posted on Jul 22, 2007
Anonymous
Master
Level 3:
Genius:
Answers
2985
Questions
0
Helped
1027895
Points
5636
Firmware problem Tell Canon customer support
I used our remote to turn on the television and now it won't do anything.
please clarify set does come on with sound and brightness/picture or nothing happens when you turn it on--no flashing lights or lights lit?
the description is a bit vague, I presume its a Sansui and if so which model?
1helpful
Sony won't turn on
Please let me know the exact model no. of your TV to accurately diagnose where the fault came from. Also, please check what is the status of the LED at the front panel, does it has a steady, blinking light, if blinking, please count how many times it will flash. Some of the blinking LED denoting an error code.
Jdvillanueva
A red lightning arrow keeps flashing on the screen and the camera isn't doin anything,what can the problem be?
Hi.
A red flashing lightening bolt can mean different things on different camera's. The most common are that you are too far away from the object you want to take a picture of. That the flash on the camera needs to be turned off and that the flash itself is charging up and won't allow a picture to be taken.
Try turning the flash off and see if it will let you take a picture.
Regards.
May 01, 2011 • Cameras
2answers
Tv comes on for 2-5 minutes then goes off
I can help you to solve your Sony KDF-E60A20 tv problem.
Does tv turn back on itself OR standby light start flashing?
If standby light flashing, please count how many times it flashing after three seconds long pause and let me know to diagnose problem.
Thanks.
Don't know what buttons on back of camera are for.
Besides the auto-flash mode, you can select fill flash, flash off, self-timer, and nighttime-view with or without flash.
Press the MODE-SELECTOR BUTTON until the desired indicator appears on the LCD PANEL.
c3015.gif Fill flash and flash off modes remain selected after you take the picture. To cancel the selection, press the mode-selection button or close and reopen the lens cover/flash to return to the auto-flash mode.
Fill flash
c3014.gif When bright light indoors or outdoors comes from behind the subject (backlighting), dark shadows (especially on faces) may occur. Use fill flash to lighten these shadows.
  1. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FILL-FLASH INDICATOR appears on the LCD PANEL.
  3. Frame your subject within the VIEWFINDER EYEPIECE.
  4. Partially depress the SHUTTER BUTTON. When the FLASH/CAMERA-READY LAMP turns off and the fill-flash indicator on the LCD panel stops blinking, fully depress the shutter button to take the picture.
Flash off
c3013.gif When you do not want to use the flash, especially indoors where flash is prohibited, such as in theaters and museums, or when you want to take twilight scenes or distant subjects that are beyond the flash range, or capture the ambiance of existing light, use the flash-off feature. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed in these situations will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FLASH-OFF INDICATOR appears on the LCD PANEL.
  4. Press the SHUTTER BUTTON to take the picture.
Self-timer with auto flash
c3016.gif Use this feature to include yourself in pictures.
  1. Use the TRIPOD SOCKET to attach the camera to a tripod or place it on another firm support.
  2. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  3. Press the MODE-SELECTOR BUTTON repeatedly until the SELF-TIMER INDICATOR appears on the LCD PANEL.
  4. Frame your subject within the VIEWFINDER EYEPIECE.
  5. Press the SHUTTER BUTTON. The SELF-TIMER LAMP will glow and then blink during the last three seconds of countdown.
    • To cancel the self-timer selection before the shutter releases, close the flash.
    • The self-timer automatically turns off after the shutter releases.
Night-view with flash
c3012.gif In this mode, the camera balances the flash and existing light exposure so you can take beautiful pictures of people at sunset or at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR with flash appears on the LCD PANEL.
  3. Frame your picture in the VIEWFINDER EYEPIECE.
  4. Press and hold the SHUTTER BUTTON for 12 seconds without lifting your finger. Note: If you remove your finger from the shutter button before 12 seconds, the shutter will time out immediately.
  5. After 12 seconds, release the shutter button to take the picture.
Night-view without flas
c3011.gif In this mode, you can capture the natural existing light of city-night scenes or fireworks at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR without flash appears on the LCD PANEL.
Samsung LN-T-4042H the picture is flashing. How
Look for screen setup for AUTO ASPECT in the setup menu, turn it OFF.
Lcd screen no picture or sound
GET IT SERVICED. THEY NEED TO CHECK SOME VOLTAGES ON THE POWER SUPPLY BOARD. POSSIBLE BAD LCD PANEL.
Turn on- Its clicks- HELP!!
Hello 4uwendy, there is a problem with lens, actually with zoom and focus initalization. Please contact your nearest Sony Service. Best regards, Arpi
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
