SOURCE: PLASMA T.V.
ten flashes from the light is a problem that needs to be issolated by a tech the 1st board to check is the PA board,and all the boards require authorization from panasonic to replace. that is why a tech must do the repair. if the unit is under warranty they must honor the warranty. extended warranty must honor the agreement you signed or purchased. there are a total of 6 boards that can cause the 10 flashes and can be costly to repair that is why I say when ever buying these types of sets get the extended warranty. these sets are no the sets of old they are not componet level repaired but board level repaired.
SOURCE: Panasonic TH-50PX60U no buttons working
The software in the cpu of this set is damaged you must reload it to fix the problem..
SOURCE: No power
I would guess it's the power unit for the TV itself.
If it's still under guarantee I would have thought you should be able to get it replaced.
SOURCE: Panasonic TH-42PX600U
There are a lot of sets that do this and it has been attributed to bad capacitors.
One thing is for sure and that is that the power supply in your set is pulling too much current. You can see the information on bad capacitors here:
http://www.badcaps.net
Then you can decide what action you want to take. IF you decide to have it serviced, call around and get bids and you take the set in and you dont get charged a service call.
