Can't see a picture on screen except when viewing from memory card
SOURCE: No image, No picture
From the Canon Website: Issue: The LCD/Electronic Viewfinder will not display an image. Solution: Special information regarding a blank or distorted screen on certain digital camera models Details: [ Hide ] Important Notice About Your Canon Product: It has recently come to our attention that the vendor-supplied CCD image sensors used in this Canon digital camera may cause the following malfunction: When the product is used in recording or playback mode, the LCD screen and/or electronic viewfinder may exhibit either a distorted image or no image at all. While reports of this malfunction have been rare in the United States, we have determined that it may occur if the product is exposed to hot and humid environments. Effective immediately, and regardless of warranty status, Canon will repair, free of charge, products exhibiting the above-mentioned malfunction if the malfunction is caused by the CCD image sensor. Canon will also cover the cost of shipping and handling in connection with this repair. U.S. residents are kindly directed to contact the Canon Customer Support Center for further assistance at 1-800-828-4040. Support hours are Monday thru Friday - 8:00 AM to 12:00 midnight; and Saturday 10:00 AM to 8:00 PM (all times EST). Alternatively, if electronic support is preferred, please send your email to [email protected] This information is for residents of the United States of America and Puerto Rico only. If you do not reside in the USA or Puerto Rico, please contact the Canon Customer Support Center in your region. We sincerely apologize for any inconvenience caused by this issue, and appreciate your understanding in this matter. Thank you for your support and patronage of Canon products.
SOURCE: PowerShot A610 Lens malfunction
What the problem looks like The problem can take any of several forms, but all involve severe color shifts and/or severe distortions of the image. The images below show two examples (courtesy of Konica Minolta) of what the problem might look like, if your camera falls prey to it. In the early stages of the problem, the camera may still capture recognizable images, but with a washed-out appearance and a strong magenta or green tint. What products may be affected? Quite a number of products may develop this problem, including digital cameras, camcorders, and even PDAs (Personal Digital Assistants) that incorporate an image sensor. The following is a list of affected models by various manufacturers that we are presently aware of. We will update this list as new information becomes available. We recommend that you check the site regularly for this and other breaking news.
SOURCE: Screen and viewfinder only shows black....no picture
Are the pictures also coming out black? If so, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
SOURCE: Canon Powershot SD1000: LCD screen display
Hopefully you resolved this already. If not, push the "DISP." button left of the MENU button. Pushing it gives you three options: black (for discreet shooting so your LCD doesn't give garner dirty looks from fellow concert goers), liveview, and liveview with info overlayed (shooting mode, ISO, etc.). Good luck!
SOURCE: 'memory card error - card locked!'
pull the card out
find the slide button on the side and slide it to the "unlock" position
put card back in
enjoi
Note: When the camera is connected to a computer using the USB cable with a
memory\picture card in the memory\picture card slot, the computer will
only see the contents of the memory\picture card.
Thanks for understanding. Please let me know if you require any additional help.
have no picture showing in any mode,flash works when button depressed bbut no picture is taken-don't hear shutter action
