Kenmore 82822 Electric Dryer Logo
Posted on Dec 12, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore Elite He3 electrical dryer runs but it does not heat up
My Kenmore Elite HE3 electrical dryer runs fine and the drum inside runs but there it does not heat up. The clothes are still wet and I already cleaned everything from the inside out it still does not heat up. If you had the same problem or if you are having the same problem please tell me what is wrong and if I can fix it.
  • 5 more comments
  • savey Dec 18, 2008
    spins and cycles fine.  All tubing is clean but no heat.
  • daustin982 Dec 25, 2008
    enmore Elite He3 electrical dryer runs but it does heat up
    but dose not dry the load.
  • roseburn Dec 28, 2008
    Kenmore Elite He3 electrical dryer runs but it does heat up
  • thecolvins Jan 23, 2009
    My Kenmore Elite HE3 has exactly the same problem..runs normal but no heat.
  • SoakingWet Feb 07, 2009
    The dryer spins and I can tell there's heat inside, but the clothes don't dry. It always takes an hour to dry a load, but now it takes 3. We've cleaned all the ducts outside of the dryer. What could be the issue inside?
  • Anonymous Mar 04, 2009
    The dryer is running but no heat.
  • Pam Biagi
    Pam Biagi Mar 28, 2009
    My dryer has to be run 2-3 times before it will dry anything...I can feel heat coming out of the duct, and it is getting warm - used to be so hot you could barely touch stuff right after it came out. I can't afford a repairman but don't know where to find the heat element...I am going to try the circuit breaker first, just to see - but if that doesn't work - what next? The manual is no help at all.
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Jan 29, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
6020
Points
14
Odd but it worked for me!! Try resetting the circuit breaker. It will not appear to have blown, this is because only 1/2 the breaker needs resetting, This is much cheaper to try before calling for service or parts. My 2002 E3t has only had this problem once and the resetting worked without further issues for 2 years now. Good luck
Anonymous
Level 2:
  • Expert 36 Answers
  • Posted on Dec 12, 2008
Anonymous
Expert
Level 2:
Answers
36
Questions
0
Helped
70282
Points
111
Mots likely your heating element is out replace it and you should be good to go
3 Related Answers
Anonymous
  • 1304 Answers
  • Posted on Oct 06, 2009
SOURCE: Kenmore Elite He3 dryer..fine on timed but leaves cloths wet auto
find the metal sensors in the drum
scratchem up with sand paper
especially if you wash rugs, sneakers , or anything with acyrlic
Anonymous
  • 16 Answers
  • Posted on Dec 13, 2008
SOURCE: Kenmore Elite HE3 dryer stays cold
you probably need a new heater element.
Anonymous
  • 163 Answers
  • Posted on Mar 06, 2009
SOURCE: Kenmore Elite HE3 Dryer clothes not dry after cycle
it sounds like a clog in vent.if yours vents up thru roof you may need to have a chimney sweep come out and sweep vent.check and make sure the vent hose is net kinked or full of lint.
HE3 Dryer not heating
check the thermal fuse and also check to make sure you have 220v at the outlet.
2helpful
My Kenmore Elite HE3 gas dryer does not heat up? What do I do?
Hi
Thanks for using FixYa. The first thing that should be checked is the Thermal fuse which is mounted to the exhaust duct inside the back cover. If this fuse goes bad the dryer will not heat and you’ll have to replace it as it cannot be repaired. If this is fine then you’ll need to check the thermostat, igniter and coils. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
My kenmore elite he3 dryer has quit heating could it be the heating element and if so where can i find it on the dryer? The model # is 110.82822103 and the serial# is MR1751757
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
1helpful
Drum turns...no heat
change the heating elament this is not hard to do it goes back the same way you take it out thank you for useing fixya
please rate me
1helpful
Dryer working but no heat
The manual says that two circuit breakers used,and that the dryer
can spin but no heat if one of them tripped, check your panel and see
if any breakers are tripped. If this was the problem,have an electrician
check the circuit.
Dryer turns on, but does not run
Try to turn the drum inside with no clothes in it, does it turn freely both ways?
Then as someone is holding the start button, hold the door switch button, then try to turn the drum counter-clock wise, and see if it will start turning on its own.
If it does start turning, then the motor is more than likely the problem.
If it dosen't then the timer is more than likely the problem.
2helpful
2answers
Dryer not heating he3 kenmore elite
repl/ thermal fuse if no heat if heating for a little while clean exhaust, and repl/ coils
Kenmore elite HE3
You need to check if the Spray Arms are knocking against an item in a basket. If the source of noise cannot be determined, run a program without plates or glassware. If the noises continue, let me know for further investigation.
Top Kenmore Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
