The remote operates the channel up/down, mute, and volume. that's it.
Do you mean you can use only the remote in channel and volume settings but can not use to turn off the tv. ok the problem is just only the power button for the remote. what you need is to clean the rubber contact inside using with an eraser. to do just unclip the lock of the remote controller to remove the housing and to access the internal part.
SOURCE: how to access AV channel on Toshiba TV model 2125RA
some sets auto-go av when you plug a rca jackin the set, others have a switch in front or back , others you might set your channel to 00 or 99 or 100 forget and work different , I the owners manual of course would tell you. but I assume u dont have it . try hooking it and letting the dvd run now find it using the remote.
good luck.
SOURCE: i was watching tv when suddenly the volume control
The front panel Tactile Switches probably need to be replaced. The part # of the switches is 23344507. You can order them through Encompass Elect. 800-638-3328.
Hope this helps,
Skyassoc
SOURCE: Toshiba (Model : 36A43) - volume goes down automatically
I am having same problem on 32 inch same problem. After playing with board with no results,I tried front buttons and found that if I held the power button in ever so slighItly as not to turn it off, it fixed problem which is the micro on/off switch, I removed the switch and used the remote and everything is back to normal, I am about to insall a used micro switch after I finish typing this but I am sure this will clear up volume problen and menu going crazy problem if not I will just leave micro switch out and use the remote, and I will get back to this board only if that micro switch still causes the problem, so if I don't post in next hour the problem is fixed and I'm more than glad to help.
SOURCE: Volume decreasing to zero by itself
Have you looked to see if the Button on the tv itself is stuck in. Press it and you might be able to feel for it sticking. If this is the case you may want to try a baby wipe or something similar to try and sort this out. (dont use a sopping wet cloth)
hope you get this sorted.
Little Dish Fitter.
SOURCE: I have an older Sanyo (approximately 8 years old)
If you are feeding the signal from your digital converter into the TV antenna input, I would input the converters signal to the TVs video input instead. I am assuming your converter has a video output signal and left & right audio so you will need cables for your audio also. If your converter has only rf output for the TV tuner input it is generally on either channel 3 or 4 and there may be a switch to set this. It is possible that when the TV scanned for channels the converter was off and it did not find a signal on 3 or 4. If you can get the TV to re-scan, be sure the converter is turned on and on an active channel. All your channel selection should be via the converter after that and the TV simply stays on 3 or 4. I would suggest looking in to getting the original remote. Try partstore.com and see if they have one for your model.
