Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
Whirlpool stackable washer/dryer. Dryer squealing
I have a Whirlpool stackable washer/dryer model #LTE6234DQ0 and the dryer is squealing. The rollers have been replaced. Any ideas?
  • buxy100 Jan 19, 2009
    washer tub is tilted how do I fix this?
  • 113 Answers
Could be the idler pulley, or the dryer seals.
Posted on Dec 16, 2008
6ya staff
SOURCE:
Whirlpool washer knob won't come off
What is the model number of your unit?
See if this service manual will help you.
Nov 24, 2012 | Whirlpool Dryers
I have a thin twin #LTE6234D that squeals when it starts. I need to know how to replace the belts that are slipping.
Which unit squeals when you start it, washer or dryer? Washer is direct drive and this noise would be from the pump area. Dryer could be Idler pulley or rear roller issue. If the belt is the issue, the front of the dryer would need to be removed in order to replace the belt, control panel needs to be removed first the disconnect the door switch. Remove the 5 screws to the front panel and replace the belt. But I would think its a idler or roller issue first over just a belt.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Sep 10, 2011 | Whirlpool Washing Machines
I HAVE A STACKABLE WASHER/DRYER THE DRYER IS NOISY ACTUALLY LOUD WHEN ON
normally u need a tune up kit,,that includes a set of rollers,belt and idler pully apx 15.00-20.00 on ebay http://www.washerwizzards.com
Dec 23, 2009 | Whirlpool Dryers
Kenmore stackable washer/dryer...dryer making HORRIBLE shrieking sound while drying...any ideas?  don't have dryer #
Hi
If your dryer is noisy, check these:
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Please revert for further assistance and Do rate the solution as "FixYa" if found useful.
Thanks
Rylee
Mar 18, 2009 | Kenmore 84052 Dryer
Loud rubber squeal sound with new clothes washer water seal.
its the wrong seal. do not lubricate it at all rubber sweals with any kind of petrolium product. many door boots look right for the model but will be thicker then needed. and will cause rubber to hit the basket.
Feb 08, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Matag stackable My Drier Squeals loud on start up
could be motor put oil on back baring aka rollers
Jan 29, 2009 | Maytag LSE7806A Top Load Stacked...
Asko stackable dryer/Bosch stackable washer compatability
If you arer going to replace the washer with a Bosch Axxis model, it will simply plug into the back of the dryer (if it is electric) because normally the dryers are 220 VAC. Works A-OK.
Nov 23, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
744 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
