Vizio VO47L 47 in. LCD TV Logo
BOB SMITH Posted on Jul 20, 2012
TV WILL NOT TURN ON - Vizio VO47L 47 in. LCD TV
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 23, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
101
Points
Tv was in a lighting storm now it won`t turn on i it fried?
TV will not power on. Red light flickers sometimes when I try to turn it on.
TV Will Not Turn On - Troubleshooting Help for Finding ...
? 2:32
https://www.youtube.com/watch?v=kEDVc-BXf0I
May 1, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV that Will Not Turn On - Troubleshooting Tips for finding symptoms and causes of ...
SONY ' eSupport - The TV will not turn on or does not have ...
https://us.en.kb.sony.com/.../the-tv-will-not-turn-on-or-does-not-have-an...
Aug 15, 2015 - The TV may not turn on if there is a power issue. Often power issues are caused by a drop in voltage in an electrical power. The power outage ...
TV has power but will not turn on - Page 2 - Community ...
community.insigniaproducts.com/t5/.../TV...power...will-not-turn-on/td...
Feb 1, 2015 - Our tv has power to it but will not turn on. The red light in the corner is lit but when we try using the remote or the power switch on the unit.
32" LCD Flat screen TV, no power, can someone help save it ...
budgetlightforum.com > Forums > Miscellaneous > Off-topic Chatter
Feb 2, 2012 - 20 posts - ‎10 authors
The tv will not power on manually or with the remote, there's no clicking noise, no LED light on the front, no signs of life. There is no obvious ...
TV Will Not Power On
Won't turn. on red standby light changes to on but then goes right back red
TV won't turn on - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have the Samsung FP-T5084 50" Plasma tv. I went to turn it on the other day, and it wouldn't turn on. No clicking. No red power indicator light. Nothing. Samsung TV LN52A650A1FXZA won't turn on, keeps clicking
Jun 11, 2015
Samsung TV won't turn on
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
More results from www.cnet.com
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old. ... I have an old type sony tv with the big back and the red power light keeps flashing and ...
How do you fix a television that won't turn on? - Ask.com
www.ask.com > Technology > Television & Video
My tv turn on for a second and after turn off. it is hitachi 52" old brand.
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
2answers
The TV will not turn on.
I have the same problem, push button to turn on tv but it only does a click like it is going to turn on and then another click bit it wont turn on. Finally a red light is just blinking.
Any suggestions, is there a freeze button or code that I need to push.
3helpful
4answers
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Flashing standby light on sony trinitron
im turn on the tv for 10 mins and next press the arrow up some times
and the tv turn on
if these not work
im turn off the tv and turn on and contiunue pressing and releasing the button arrow up in the front pannel of the tv
then the tv turn on
these work in my tv
4answers
Closed caption always comes on when I turn on TV!
Same thing here!!!!! It is soooooo annoying! Can't do it from the TV and the CC does not turn it off either.
Any suggestions would be so appreciated.
2answers
The tv timer won't turn off
Nope sorry my friend the timer does not have a function to no let the TV set turn on, It only hhas a function to turn off the set. You have another problem with the TV set I bet you 100% Sometimes someone will use the timer funtion to have the TV set turn off and then at turn off or even turn on a componet fails and goes bad. there is no way a TV timer will prevent the TV set from turning on. there is most likly a problem in the TV sets power supply or the sweep power supply. Have it checked out by a pro and they will tell you the same thing. Good guess though, but it does not simply work that way, Sorry. Good Luck
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
