Please tell where to start and how to go about it.
You can download the english language pack from windows update, that you can find from your start menu, it will be in optional updates.
after you have installed english or if it is already installed, then open control panel, under clock language and region click on change display language, under display language you can change the language to another.
SOURCE: Change Windows XP language from Chinese to English
If the menus are all in Chinese then you will need to install an Enlgish version of Windows XP.
SOURCE: language change of OS Windows Vista Home basic
spanish may be already installed as package;if not you can install any language from the disk..
on a personal note vista has great graphics but the system runs slow.if the machine is installed with vista its upto speed so if you was to install xp on the machine you would have a nice fast machine.
SOURCE: change language to English
This might be a problem.. Windows controls the actual display language (thats the dialog boxes, the windows and all the screen messages you see).
If you have a german copy of windows it might be just german. That means you might NOT be able to change the display language to english.
IF you have what's called windows MUI you might be able to change the display language.
Ask the guy or company you bought it from if they have windows CD's. You're likely going to need them. See if by any remote chance you DO have Windows XP MUI (stands for multi user interface)
It's unlikely you do, but at least ask.
There are options to change the language but it's usually not for the display it's for spelling or how dates and the like appear.
SOURCE: CHANGING CHINESE LANGUAGE TO ENGLISH
wat I did was, I installed an elgish version of vista and then used the key given for the chinese vista for registration. Hence, I got both english version of vista and got it licensed too.
SOURCE: how can i change language settings on acer aspire
hi. i can help you.
open up your control panel and you will see a selectioin for language. open that and you will be able to set everything to english.
