I see a small camera on the top right side of it, but i can't access or find where the webcam settings are. HELP!
Not sure which model you have but if by chance you have the T410 model, instructions for using the camera can be found on page 27 of the manual at the following link. This looks like a very nice device!
http://s3.velocitymicro.com/vmcruz/T410/manual/Cruz_Tablet_T410_User_Guide.pdf
SOURCE: Won't turn on - I hit the power button on my
Usually when you have what i would call a power lock out. you must remove the battery and wait a few minutes and put it back in, and it usually fires up. Most electronics have these problems. If you are 100% sure the unit is charged with a green light, or no light at all, and you pressing of the top button does not turn it on then remove the back, it is very easy. You can lift it up with your fingernail. If new and faint of heart, under warranty, and all, then make that phone call. Otherwise, you must attempt to remove the connects to the big grey squared battery for a moment, which is said to be easy to do and the battery easy to replace. Look for instruction on the removal on YouTube, or other sites. However, I am more than sure this will solve the problem, unless it has been in liquid, a power surge, dropped, or in excessive heat or cold, or touched by some with "bad karma" for electronics (just kidding). hope this helps.
SOURCE: Velocity Micro Cruz ereader screen
Mine hasn't frozen (yet) but if this is a more or less "permanent" freeze there is a reset pinhole between the power button and the usb connector. If this is in intermittent problem, the only thing I can say is that the device is poorly designed, the screen is just not very responsive and the CPU chip must be under-powered so it is very slow to react. If you tap-tap-tap a lot on the screen or the power button you might be overloading the CPU. Mine seems to freeze from time to time but eventually "catches up" and then starts working again. Sorry, but I definitely put this product only a half step above the junk category. I also own an Ipod Touch and holy cow there is a world of difference in quality and performance between the two.
Oh yeah - you might try calibrating the screen but I doubt that it will help much. The "calibration" suggestion really seems like more of a distraction tactic to make new owners think they are really doing something cool to make it work better out of the box.
If you can still return the machine for a refund I suggest you do - lots of new tablets andf "readers" will be hitting the stores within a few weeks and Best Buy will be selling these for $50 just to unload them!
SOURCE: my velocity micro cruz won't
Hold down the power button - even after the shut down message for a minute or so - then restart.
SOURCE: My Velocity Micro Cruz Reader
press power button in for about 6/7 seconds then start again,should reset.Otherwise corrupted installation ,,re-installl OS.
SOURCE: My velocity micro cruz t301
Try this.
1. Carefully take the battery out.
2. And you should see a white cable attached to an 'outlet'.
3. Unplug it and then wait about five seconds. plug it back in.
If this helpful, please give a testimonial and vote by pressing button thumbs up.
Sincerely,
Thiyaga
