no, this is not normal. air should be cooler.
Be careful. i do not know. set at highest setting and let it run. while running, reduce setting to the lowest over a few minutes. at a lower setting you should be able to tell that the compressor has started. run it for 5 minutes, then
unplug your machine. next, feel the cooling coils to see if they are very cold. if they are not cold, your unit needs to be serviced.
It is normal for a dehumidifier to discharge warm air. A dehumidifier is really an air conditioner - a fan blows humid room air across a cold fin coil that causes the moisture to condense on it and drip into a container - thus cooling AND dehumidifying the air. The cool air is blown over the warm coil and discharged out the back. A dehumidifier WILL normally increase the temperature of the room it is in. You can do the same thing with sitting an A/C unit on a stool in a room. Room air will be drawn in, cold air will come out the front, hot air out the back and water will drip on the floor. And, the room will get hotter, due to what is called "heat of compression" even though you're running an A/C unit.
A/C removes the heat found in the air and so gives out slightly warf flows but normally this is cooled of by water but that is why air con home units are vented to the outside atmos
Hi,The compressor is not starting... the unit is junk...
There are many reasons why a dehumidifier willnot work or collect water. Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Hi, The compressor basically blew up inside...not worth fixing... chuck it and buy a new one...
There can be many reasons why a dehumidifier will
Yes! A dehumidifier is an entire AC system in one box. First the air passes thru a very cold coil causing moisture in the air to condense and run away. Then the air is re-heated thru a hot coil (the other half of the AC) and blown back into the room. The net result MUST be a net increase in temperature because of the heat added by the mechanical process.
A) The warm air that is being expelled from your dehumidifier is normal. When the unit is dehumidifying the compressor is working which causes the compressor to become quite hot. In order to avoid having the compressor overheat, air is drawn by the compressor at a rapid rate and the heat is then transferred to the air which must be expelled from the unit. The warm air will stop shortly after the unit has reached the desired humidity. This warm air should not change your room temperature by more than a degree or two.
If your dehumidifier is one that runs at colder temps so it does not ice up, it will have a heater in it to prevent this. That is the warm air you are feeling.
