I have a whirlpool duet sport washer and every time I start a cycle the water pours out of the detergent compartment and down the front of the machine. I pulled out the compartment and the water does go through but too slowly.
When you take out the drawer you can reach inside and at the front of that compartment there should be an opening where the water goes into. I have seen many times where something is blocking that opening. The only other thing would be something stuck in the hose that attaches to that opening and feeds water to the tub. It sounds impossible but I have pulled underwear and socks out of that hose several times. Best way to access that hose it to take the outer clamp off of the door boot and reach in there, disconnect the hose and pull it out. Getting the clamp back on can be a little tricky if you haven't done it before so it may be best to call for a technician. Hope this helps.
I have the same problem. THe water is not flowing inside the washer.Instead it is leaking out of the detergent dispenser.
Please help?
Ed
